楼主: ABC
[经验分享] (更新0.49的asuswrt.py)修改asuswrt.py来给让padavan检测设备是否...
ABC 手机认证
论坛风云人物
 楼主| 发表于 2017-6-3 16:57:29 | 显示全部楼层
hassbian 发表于 2017-6-3 16:34
之前有个pandavn.py和个一样的吗
官方最新版,应该有改善
发表于 2017-6-3 23:24:26 | 显示全部楼层
楼主辛苦,留名细看
发表于 2017-6-8 21:47:56 | 显示全部楼层
学习了
论坛风云人物
发表于 2017-6-17 21:26:29 | 显示全部楼层
A总666
发表于 2017-6-19 22:35:50 | 显示全部楼层
之前自己折腾过,看看帖子果然明白多了!
发表于 2017-7-4 00:52:34 | 显示全部楼层
老毛子华硕固件显示错误,求解决
The following errors have been logged this session:
2017-07-04 00:51:51 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform padavanwrt
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/device_tracker/__init__.py", line 151, in async_setup_platform
    platform.get_scanner, hass, {DOMAIN: p_config})
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/home/homeassistant/.homeassistant/custom_components/device_tracker/padavanwrt.py", line 100, in get_scanner
    scanner = AsusWrtDeviceScanner(config[DOMAIN])
  File "/home/homeassistant/.homeassistant/custom_components/device_tracker/padavanwrt.py", line 149, in __init__
    data = self.get_asuswrt_data()
  File "/home/homeassistant/.homeassistant/custom_components/device_tracker/padavanwrt.py", line 191, in get_asuswrt_data
    result = self.connection.get_result()
  File "/home/homeassistant/.homeassistant/custom_components/device_tracker/padavanwrt.py", line 319, in get_result
    self.connect()
  File "/home/homeassistant/.homeassistant/custom_components/device_tracker/padavanwrt.py", line 364, in connect
    password=self._password, port=self._port)
  File "/home/homeassistant/.homeassistant/deps/pexpect/pxssh.py", line 279, in login
    spawn._spawn(self, cmd)
  File "/home/homeassistant/.homeassistant/deps/pexpect/pty_spawn.py", line 267, in _spawn
    'executable: %s.' % self.command)
pexpect.exceptions.ExceptionPexpect: The command was not found or was not executable: ssh.
发表于 2017-7-5 18:59:45 | 显示全部楼层
保存备用
iLee
iLee
发表于 2017-7-5 20:07:17 | 显示全部楼层
谢谢了。谢谢分享
群名叫iLee
GitHub叫ileez
Docker Hub叫zlee
这么多名字都是被逼的。。。
发表于 2017-7-23 17:35:39 | 显示全部楼层
https://github.com/PaulAnnekov/h ... ob/master/README.md
我用这个效果也不错, 楼主这个我没有测试成功,  错误信息没有,但是也搜不出设备
发表于 2017-7-24 01:54:29 | 显示全部楼层
这个功能挺不错的
GMT+8, 2025-9-17 03:31 , Processed in 0.850849 second(s), 12 queries , MemCached On.
