- 积分
- 664
- 金钱
- 526
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 664
- 金钱
- 526
- HASS币
- 0
发表于 2023-4-6 09:09:39
显示全部楼层
配置密钥后无法链接了
Home Assistant 2023.3.5
Supervisor 2023.04.0
Operating System 9.5
前端版本: 20230309.1 - latest
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 383, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/bemfa/__init__.py", line 31, in async_setup_entry
await service.async_start(
File "/config/custom_components/bemfa/service.py", line 37, in async_start
self._bemfa_mqtt.connect()
File "/config/custom_components/bemfa/mqtt.py", line 79, in connect
self._mqttc.connect(MQTT_HOST, MQTT_PORT, MQTT_KEEPALIVE)
File "/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py", line 914, in connect
return self.reconnect()
File "/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py", line 1044, in reconnect
sock = self._create_socket_connection()
File "/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py", line 3685, in _create_socket_connection
return socket.create_connection(addr, timeout=self._connect_timeout, source_address=source)
File "/usr/local/lib/python3.10/socket.py", line 845, in create_connection
raise err
File "/usr/local/lib/python3.10/socket.py", line 833, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
