楼主: zjhcr
[基础教程] 汉非太阳能(光伏)控制器接入ha小白级教程
发表于 2023-9-9 09:29:22 | 显示全部楼层
照着原来楼主的方法,无论是自己写yaml,还是原文不动地套用Yaml到Packages里面,都会报错,如参数无效config invalid.求解。我的要求是将某个地址如3004的充电状态显示出来,如1表示充电,0表示放电,2表示静置。无法怎么写都失败。
 楼主| 发表于 2023-9-27 00:22:27 | 显示全部楼层
sayinzest 发表于 2023-9-9 09:29
照着原来楼主的方法,无论是自己写yaml,还是原文不动地套用Yaml到Packages里面,都会报错,如参数无效confi ...
帖上你的代码上来看看
发表于 2023-10-1 21:55:24 | 显示全部楼层
zjhcr 发表于 2023-9-27 00:22
帖上你的代码上来看看
template:
  - trigger:
      - platform: mqtt
        topic: tele/tasmota_D368DE/RESULT
    #电池电压(数据正确)
      - name: Voltage
        unique_id: v001
        unit_of_measurement: "V"
        state: "{{ (trigger.payload.split(',')[3] | float/100) }}"
    #电池电流(数据正确)
      - name: Current
        unique_id: c001
        unit_of_measurement: "A"
        state: "{{ (trigger.payload.split(',')[4] | float/100) }}"
    #电池温度(数据正确)
      - name: Temperature
        unique_id: tmp001
        unit_of_measurement: "°C"
        state: "{{ (trigger.payload.split(',')[9] | float-100) }}"
     #电池功率(数据OK)
      - name: Battery Power
        unique_id: bp01
        unit_of_measurement: "W"
        state: "{{ ((trigger.payload.split(',')[3] | float/100) * (trigger.payload.split(',')[4] | float/100)) | round(2) }}"
        state_class: measurement
    #电池设计容量(数据OK)
      - name: Amp Hours Remaining
        unique_id: ahc01
        unit_of_measurement: "AH"
        state: "{{ (trigger.payload.split(',')[5] | float/1000) }}"
    #电池百分比容量(数据ok,下面的60000是电池原始容量)
      - name: Batterycapacity
        unique_id: 000060000-1
        unit_of_measurement: "%"
        state: "{{ (trigger.payload.split(',')[5] | float/250000*100) }}"
    #电池充入电量(数据OK)
      - name: Chargingenergy
        unique_id: ce011
        unit_of_measurement: "kWh"
        state: "{{ (trigger.payload.split(',')[7] | float/100000) }}"
        state_class: total
        device_class: energy
     #电池放电电量(数据OK)
      - name: Dischargingenergy
        unique_id: de001
        state: "{{ (trigger.payload.split(',')[6] | float/100000) }}"
        state_class: total
     #电池充放电时间(数据OK,下面的60是电池的容量可变数据)
      - name: Battery Life Hours
        unique_id: blh001
        unit_of_measurement: "Hours"
        state: "{{ (trigger.payload.split(',')[13] | float/60) }}"
     #电池充放电状态 (1表示充电,0表示放电)
      - name: charge_state
        unique_id: cs001
        state: "{{ (trigger.payload.split(',')[12]) }}"
发表于 2023-10-1 21:58:13 | 显示全部楼层
帖上你的代码上来看看
发了一个贴子,在这里
https://bbs.hassbian.com/thread-22750-1-1.html
感谢帮助!
发表于 2023-10-29 21:34:45 | 显示全部楼层
请教一下,上位机不是需要发送查询指令,下位机才能返回相应的查询信息吗?怎么做的让下位机自动像上位机发送信息呢?
发表于 2024-2-10 21:44:04 | 显示全部楼层
楼主esp-link 这个软件可以提供下载吗。 谢谢!!
发表于 2024-5-9 17:14:13 | 显示全部楼层
感谢楼主,先收藏,以后时间也折腾下
 楼主| 发表于 2024-5-10 17:10:53 | 显示全部楼层
https://github.com/jeelabs/esp-link
发表于 2024-5-11 11:38:04 | 显示全部楼层
6666666666
发表于 2024-7-3 16:10:16 | 显示全部楼层
esp-link大佬这个在哪里下载
GMT+8, 2025-9-18 04:10 , Processed in 0.869546 second(s), 14 queries , MemCached On.
