楼主: qingyu1993
[新奇玩法] MQTT调试工具MQTT-Explorer支持docker部署啦!可以在远程管理了!
发表于 2021-12-13 01:11:36 | 显示全部楼层
感谢分享!
发表于 2021-12-13 14:46:30 | 显示全部楼层
windows上有uwp版本,好用的
发表于 2022-8-18 13:00:07 | 显示全部楼层
老哥们求教,按照流程配置完了之后docker启动报错。
**** Config file not found, copying sample config ****
**** Newer version found. Grabbing latest code ****
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:02:10 --:--:--     0
curl: (28) Failed to connect to github.com port 443: Operation timed out
**** Updating versions ****
tar: /tmp/ac2mqtt.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
[cont-init.d] 30-config: exited 0.
[cont-init.d] 99-custom-files: executing...
[custom-init] no custom files found exiting...
[cont-init.d] 99-custom-files: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
ifelse: fatal: unable to exec --net=host: No such file or directory
[cmd] --net=host exited 127
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
发表于 2022-8-18 15:01:12 | 显示全部楼层
直接用EMQ服务器,web界面管理如何?
 楼主| 发表于 2022-8-19 13:32:31 | 显示全部楼层
需要科学上网吧
发表于 2022-12-29 15:47:19 | 显示全部楼层
这个软件好赞,找了2天工具,终于找到一款完美的
GMT+8, 2025-9-18 04:21 , Processed in 1.117136 second(s), 13 queries , MemCached On.
