查看: 13597|回复: 18
[新奇玩法] 推荐一个专门为hass开发的IP摄像头NVR,功能非常强大
发表于 2021-10-20 22:50:32 | 显示全部楼层 |阅读模式
刚在网上看到一款专门为hass开发的NVR应用,功能非常强大,分享给大佬们
下面是链接和简介
Frigate NVR
Introduction
A complete and local NVR designed for Home Assistant with AI object detection. Uses OpenCV and Tensorflow to perform realtime object detection locally for IP cameras.
Use of a [color=var(--ifm-link-color)]Google Coral Accelerator is optional, but strongly recommended. CPU detection should only be used for testing purposes. The Coral will outperform even the best CPUs and can process 100+ FPS with very little overhead.
  • Tight integration with Home Assistant via a [color=var(--ifm-link-color)]custom component
  • Designed to minimize resource use and maximize performance by only looking for objects when and where it is necessary
  • Leverages multiprocessing heavily with an emphasis on realtime over processing every frame
  • Uses a very low overhead motion detection to determine where to run object detection
  • Object detection with TensorFlow runs in separate processes for maximum FPS
  • Communicates over MQTT for easy integration into other systems
  • Recording with retention based on detected objects
  • Re-streaming via RTMP to reduce the number of connections to your camera
  • A dynamic combined camera view of all tracked cameras.
参与人数 1金钱 +8 收起 理由
firewater + 8 论坛有你更精彩!
发表于 2021-10-22 02:31:07 | 显示全部楼层
很厉害!如果能买到coral usb就更厉害了
 楼主| 发表于 2021-10-22 08:31:42 | 显示全部楼层
这个就成本蹭蹭的上去了
发表于 2021-10-22 09:18:28 | 显示全部楼层
使用了下,cpu j3455识别,5帧,占用不高。有个问题,好像人静止的时候,不会触发。这样就没办法静止人体判断了。还不知道怎么优化
 楼主| 发表于 2021-10-22 12:45:54 来自手机 | 显示全部楼层
sangood 发表于 2021-10-22 09:18
使用了下,cpu j3455识别,5帧,占用不高。有个问题,好像人静止的时候,不会触发。这样就没办法静止人体判 ...
你是装在hass里还是单独装的?
发表于 2021-10-23 00:57:10 | 显示全部楼层
散步d小螃蟹 发表于 2021-10-22 08:31
这个就成本蹭蹭的上去了
因为芯片荒,coral usb到处都没货。想买都买不到....
发表于 2021-10-23 14:38:14 | 显示全部楼层
不用买usb,直接买m.2或者minipcie的,便宜而且有货而且性能好。当然前提是你的frigate跑的主机上有这个接口。我建议是搞个有点性能的x86既可以做nas,同时用proxmox虚拟机跑frigate和ha,这样录像也可以直接录制到nas硬盘上,海康录像机就可以不用了,顺便可以跑HA。反正我家有6路摄像头,肯定要上x86的,所以正好。如果你只有一路,随便玩玩那么树莓派也可以但是usb coral太贵了,那个钱可以直接买一个nas
参与人数 1金钱 +8 收起 理由
firewater + 8 赠人玫瑰,手留余香!
发表于 2021-10-23 14:45:22 | 显示全部楼层
不知道你怎么设置的,默认情况下就是会一直识别静止物体的
发表于 2021-10-25 22:04:12 | 显示全部楼层
cameras:
  # Required: name of the camera
  camera_lvroom:
    ffmpeg:
      inputs:
        - path: rtsp://[email protected]:554/stream2
          roles:
            - detect
            #- rtmp
    detect:
      width: 640
      height: 640
我这里默认 设置也不行啊,奇怪了。只要我静止不动,统计不到人。sensor.camera_lvroom_person 这个实体里面是0. debug也显示不出person 百分比。
发表于 2021-10-26 09:40:28 | 显示全部楼层
散步d小螃蟹 发表于 2021-10-22 12:45
你是装在hass里还是单独装的?
单独安装的,接了2个720p的摄像头。5帧。
GMT+8, 2025-9-17 03:26 , Processed in 0.679533 second(s), 13 queries , MemCached On.
