楼主: 田木
[基础教程] 装了samba share但是win10系统还是找不到HASS!
发表于 2022-4-1 20:01:30 | 显示全部楼层
我的情况和楼主类似. 手机可以访问.但是WIN10就不行.........死都不行.......SMA 1.0也都开了.
发表于 2022-4-5 14:49:12 | 显示全部楼层
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
waiting for connections
check_for_master_browser_fail: Forcing election on workgroup WORKGROUP subnet 192.168.2.53
send_election_dgram: Sending election packet for workgroup WORKGROUP on subnet 192.168.2.53
run_elections: >>> Won election for workgroup WORKGROUP on subnet 192.168.2.53 <<<
become_local_master_browser: Starting to become a master browser for workgroup WORKGROUP on subnet 192.168.2.53
Samba name server 114.114.114.114 is now a local master browser for workgroup WORKGROUP on subnet 192.168.2.53
become_local_master_browser: Awaiting potential browser state. Current state is 4
Registered MSG_REQ_POOL_USAGE
我的也是如此
发表于 2022-4-6 09:16:57 | 显示全部楼层
在allow_hosts:那里加上一行你的pc的ip地址,就能解决。
发表于 2024-1-5 08:47:56 | 显示全部楼层
解决了吗 我也出现这个问题。
发表于 2024-5-26 11:30:08 | 显示全部楼层
mars.z 发表于 2021-9-19 19:07
. 兼容模式改成true,然后把win10的 启用或关闭windows功能内的SMB1.0打开再试试吧 ...
这个是对的
发表于 2024-11-24 19:29:18 | 显示全部楼层
楼主解决了吗,我也是同样的情况
GMT+8, 2025-9-18 04:21 , Processed in 0.699680 second(s), 12 queries , MemCached On.
