查看: 16452|回复: 26
[信息发布] 请教下各位大神关于小米网关的问题
发表于 2017-10-11 15:39:13 | 显示全部楼层 |阅读模式
请问各位大神,请问要怎样设置才能把小米网关加入到homeassistant
Home Assistant
0.55.0
在configuration.yaml文件最后加入了密码等信息
试了好多种方法,最终结果都一样
请问是哪里出了问题?
发表于 2017-10-11 15:47:43 | 显示全部楼层
xiaomi => xiaomi_aqara
发表于 2017-10-11 16:04:59 | 显示全部楼层
楼上正解。
 楼主| 发表于 2017-10-11 16:10:25 | 显示全部楼层
uavana 发表于 2017-10-11 15:47
xiaomi => xiaomi-aqara
试过了,还是一样的
发表于 2017-10-11 16:20:31 | 显示全部楼层
yxm203 发表于 2017-10-11 16:10
试过了,还是一样的
xiaomi_aqara  ,应该是下划线吧!
发表于 2017-10-11 16:47:33 | 显示全部楼层
借题问下,和楼主同样问题
xiaomi_aqara:
  gateways:
      - mac: 34CE00xxxxxxx
        key: nhe
出来就报错了,而且这个错误还不是因为0.55系统,之前版本也同样问题
2017-10-11 16:44:22 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2017-10-11 16:44:22 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2017-10-11 16:44:29 ERROR (Thread-3) [homeassistant.util.package] Unable to install package PyXiaomiGateway==0.5.1: Command "/srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-128pclxt/pyCrypto/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-atdta7mk-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.5/pyCrypto" failed with error code 1 in /tmp/pip-build-128pclxt/pyCrypto/
2017-10-11 16:44:29 ERROR (MainThread) [homeassistant.setup] Not initializing xiaomi_aqara because could not install dependency PyXiaomiGateway==0.5.1
2017-10-11 16:44:29 ERROR (MainThread) [homeassistant.setup] Setup failed for xiaomi_aqara: Could not install all requirements.
发表于 2017-10-11 17:14:31 | 显示全部楼层
是的..下划线
发表于 2017-10-11 17:15:45 | 显示全部楼层
tqleopard 发表于 2017-10-11 16:47
借题问下,和楼主同样问题
xiaomi_aqara:
  gateways:
mac 地址改成小写
发表于 2017-10-11 20:02:39 | 显示全部楼层
问题依旧
是否能单独安装pyxiaomigatway的包?
 楼主| 发表于 2017-10-12 09:29:52 | 显示全部楼层
大小写都试过了。各个版本还都试过,不知道跟路由器有没有关系
GMT+8, 2025-8-10 15:37 , Processed in 0.340034 second(s), 11 queries , MemCached On.
