查看: 26923|回复: 33
[进阶教程] 制作油烟传感器来进行油烟机联动控制
发表于 2021-8-19 19:55:23 | 显示全部楼层 |阅读模式
我爸爸之前每次做菜,都不喜欢开油烟机,于是我的灵感来了,决定做一个油烟机自动控制,当然,焊接部分非常感谢我爸爸的帮忙
准备环境和材料
硬件环境
  1. NODEMCU ESP8266
  2. TGS2600传感器
    规格资料表: 规格资料表
    传感器特性:传感器特性
  3. LCD2600
    产品介绍:https://wiki.dfrobot.com.cn/_SKU ... %E5%85%BC%E5%AE%B9_
    LCD数据手册: https://image.dfrobot.com/image/ ... 780%20Datasheet.pdf
    PCA8574数据手册:https://www.dfrobot.com.cn/goods-184.html
软件部分
  1. 一台linux操作系统
  2. ESPHOME
    执行以下命令安装:
sudo pip3 install esptool esphome
配置软件固件:
我们定义了如下固件配置:
esphome:
  comment: Oil fume detection sensor for kitchen and alarm
  platform: ESP8266
  board: nodemcuv2
  project:
    version: 1.0.0
  platformio_options:
    upload_speed: 115200
  includes:
    - status_ext_led.h
custom_component:
- lambda: |-
    auto status_ext_led = new Status_ext_ledComponent();
    return {status_ext_led};
debug:
# Logger must be at least debug (default)
logger:
  level: debug
# Enable Home Assistant API
mqtt:
  broker: ""
  username: ""
  password: ""
  discovery: true
  birth_message:
    topic: lampblack-alert/status
    payload: online
  will_message:
    payload: offline
i2c:
  sda: D2
  scl: D3
ota:
  safe_mode: true
  password: ""
wifi:
  ssid: ""
  password: ""
  manual_ip:
    static_ip: 192.168.101.5
    gateway: 192.168.101.1
    subnet: 255.255.255.0
    dns1: 192.168.101.254
    dns2: 192.168.101.1
  ap:
    ssid: "lampblack-alert"
    password: ""
captive_portal:
web_server:
  port: 80
status_led:
  pin:
    number: D4
    inverted: true
  - platform: adc
    pin: A0
    update_interval: 1s
    device_class: ""
    state_class: "measurement"
    unit_of_measurement: ppm
    filters:
      - multiply: 4.85
      - lambda: return 100 * (x - 0.5) / 4;
      - offset: 1.6
  - platform: wifi_signal
    name: "lampblack WiFi Signal Sensor"
    update_interval: 60s
binary_sensor:
  - platform: status
display:
  - platform: lcd_pcf8574
    dimensions: 20x4
    address: 0x27
    lambda: |-
      if(id(mqtt_client)->is_connected()) {
        it.strftime("%Y-%m-%d %H:%M", id(system_time).now());
        it.printf(0,1,"Sensor: %.1f", id(lampblack).state);
      } else {
        it.print(0,0,"System Booting...");
switch:
  - platform: restart
text_sensor:
  - platform: wifi_info
    ip_address:
      name: Lampblack IP Address
    ssid:
      name: Lampblack Connected SSID
    bssid:
      name: Lampblack Connected BSSID
    mac_address:
      name: Lampblack Mac Wifi Address
  - platform: version
  - platform: mqtt_subscribe
    internal: true
    topic: home/kitchen/lampblack/backlight_ctl/set
    on_value:
      then:
         - lambda: |-
             if(x == "ON") {
               id(frontend).backlight();
             } else if(x == "OFF")  {
               id(frontend).no_backlight();
             id(mqtt_client).publish("home/kitchen/lampblack/backlight_ctl", x.c_str());
time:
  - platform: sntp
本项目包含自定义代码,代码文件status_ext_led.h实现如下:
#include "esphome.h"
class Status_ext_ledComponent : public Component {
 public:
  void setup() override {
    // This will be called once to set up the component
    // think of it as the setup() call in Arduino
    this->pin = new GPIOPin(2, OUTPUT, true);
  void loop() override {
    // This will be called very often after setup time.
    // think of it as the loop() call in Arduino
    if(((App.get_app_state() & STATUS_LED_WARNING) == 0u) && ((App.get_app_state() & STATUS_LED_ERROR) == 0u)) {
      this->pin->digital_write(true);
  private:
    GPIOPin *pin;
NODEMCU ESP82666的端口映射表可以从
硬件设计
对于没有焊接经验的初学者,可以先使者使用以下模块:
  1. 降压板
  2. 0-5V ADC模块
当然也可以常识实际焊接,这里我会将电路图放出来
分压电路
稳压电路
我和我爸爸用的洞洞板,但第一次尝试着做了下PCB,也丢出来吧:
分压电路PCB
稳压电路PCB
HA背光控制设置
在HA设置一个按钮,进行背光控制,配置如下:
  - platform: mqtt
    command_topic: "home/kitchen/lampblack/backlight_ctl/set"
    state_topic: "home/kitchen/lampblack/backlight_ctl"
    payload_on: "ON"
    payload_off: "OFF"
    state_on: "ON"
    state_off: "OFF"
NODERED流设置
        "id": "174b51c.d7bd3ae",
        "type": "group",
        "z": "693cee39.d45af",
        "name": "油烟",
        "style": {
            "label": true
        "nodes": [
            "f18bfe36.06fb88",
            "d478ce7a.0a10f8",
            "35901cb713be13d4",
            "66673a68930b495f",
            "2b4e225396df09f5",
            "f2d4bdb86a889e9a",
            "55a5cabe4e031a6a",
            "6a2dfdb29254b4f8",
            "1695652c9f622c78",
            "03ec607eb7801fc3",
            "f9e7ae09d000adfa",
            "7255edefed08d4fe",
            "983d6f01669809cd",
            "96f4ac0a46cfa49b",
            "72bb77b5a3a0b0da",
            "a65f5239c50bfbc0",
            "32f5ec3c6cf8b4cf",
            "7fdac22db5ee6b02",
            "acb69f7d18961b7f",
            "1491e89a90f76316",
            "8507f42368354dea",
            "e03e6ac38d6e004e",
            "882ba4576c867324"
        "x": 14,
        "y": 579,
        "w": 1632,
        "h": 802
        "id": "f18bfe36.06fb88",
        "type": "mqtt in",
        "g": "174b51c.d7bd3ae",
        "name": "",
        "topic": "lampblack-alert/status",
        "qos": "0",
        "datatype": "auto",
        "broker": "6170f2b1.2e2f14",
        "nl": false,
        "rap": true,
        "rh": 0,
        "x": 160,
        "y": 760,
        "wires": [
                "d478ce7a.0a10f8"
        "id": "d478ce7a.0a10f8",
        "type": "switch",
        "name": "",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "eq",
                "v": "online",
                "vt": "str"
                "t": "eq",
                "v": "offline",
                "vt": "str"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 450,
        "y": 760,
        "wires": [
                "96f4ac0a46cfa49b"
                "32f5ec3c6cf8b4cf"
        "id": "35901cb713be13d4",
        "type": "server-state-changed",
        "name": "油烟浓度",
        "server": "3c87f99d.1fa9b6",
        "version": 3,
        "exposeToHomeAssistant": false,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "sensor.lampblack",
        "entityidfiltertype": "exact",
        "outputinitially": false,
        "state_type": "num",
        "haltifstate": "",
        "halt_if_type": "str",
        "halt_if_compare": "is",
        "outputs": 1,
        "output_only_on_state_change": true,
        "for": 0,
        "forType": "num",
        "forUnits": "minutes",
        "ignorePrevStateNull": false,
        "ignorePrevStateUnknown": false,
        "ignorePrevStateUnavailable": false,
        "ignoreCurrentStateUnknown": false,
        "ignoreCurrentStateUnavailable": false,
        "outputProperties": [
                "value": "",
                "valueType": "entityState"
                "property": "data",
                "value": "",
                "valueType": "eventData"
                "property": "topic",
                "value": "",
                "valueType": "triggerId"
        "x": 120,
        "y": 900,
        "wires": [
                "66673a68930b495f"
        "id": "66673a68930b495f",
        "type": "api-current-state",
        "name": "查询上限",
        "version": 2,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.you_yan_ji_qi_dong_shang_xian",
        "blockInputOverrides": false,
                "property": "max",
                "value": "",
                "property": "max_data",
                "value": "",
                "valueType": "entity"
        "override_topic": false,
        "state_location": "payload",
        "override_payload": "msg",
        "entity_location": "data",
        "override_data": "msg",
        "x": 340,
        "y": 900,
        "wires": [
                "2b4e225396df09f5"
        "id": "2b4e225396df09f5",
        "name": "查询上限",
        "version": 2,
        "outputs": 1,
        "halt_if": "",
        "entity_id": "input_number.you_yan_ji_guan_bi_xia_xian",
                "property": "min",
                "value": "",
                "property": "min_data",
                "value": "",
        "x": 560,
        "y": 900,
        "wires": [
                "f2d4bdb86a889e9a"
        "id": "f2d4bdb86a889e9a",
        "type": "switch",
        "name": "比较阀值",
        "rules": [
                "t": "gte",
                "v": "max",
                "vt": "msg"
                "t": "lte",
                "v": "min",
                "vt": "msg"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 760,
        "y": 900,
        "wires": [
                "6a2dfdb29254b4f8"
                "1695652c9f622c78"
        "id": "55a5cabe4e031a6a",
        "type": "ha-entity",
        "name": "油烟机自动控制状态指示",
        "version": 1,
        "debugenabled": false,
        "outputs": 1,
        "entityType": "binary_sensor",
        "config": [
                "property": "name",
                "value": "油烟机自动控制状态指示"
                "property": "device_class",
                "value": ""
                "property": "icon",
                "value": ""
                "property": "unit_of_measurement",
                "value": ""
        "state": "payload",
        "stateType": "msg",
        "attributes": [],
        "resend": true,
        "outputLocation": "",
        "outputLocationType": "none",
        "inputOverride": "allow",
        "outputOnStateChange": false,
        "outputPayload": "$entity().state ? \"on\": \"off\"",
        "outputPayloadType": "jsonata",
        "x": 1250,
        "y": 900,
        "wires": [
        "id": "6a2dfdb29254b4f8",
        "type": "change",
        "name": "指示启动油烟机",
        "rules": [
                "t": "move",
                "p": "payload",
                "pt": "msg",
                "to": "current",
                "tot": "msg"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 950,
        "y": 840,
        "wires": [
                "55a5cabe4e031a6a",
                "7255edefed08d4fe"
        "id": "1695652c9f622c78",
        "type": "change",
        "name": "指示关闭油烟机",
        "rules": [
                "t": "move",
                "p": "payload",
                "pt": "msg",
                "to": "current",
                "tot": "msg"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 940,
        "y": 960,
        "wires": [
                "55a5cabe4e031a6a",
                "983d6f01669809cd"
        "id": "03ec607eb7801fc3",
        "type": "api-call-service",
        "name": "发送开启通知",
        "version": 3,
        "service_domain": "persistent_notification",
        "service": "create",
        "entityId": "",
        "data": "{\"message\":\"当前油烟/空气质量浓度:{{current}} ppm,设备应自动开启!\",\"title\":\"设备控制\"}",
        "dataType": "json",
        "mergecontext": "",
        "mustacheAltTags": false,
        "outputProperties": [],
        "queue": "none",
        "x": 1540,
        "y": 820,
        "wires": [
        "id": "f9e7ae09d000adfa",
        "name": "发送关闭通知",
        "version": 3,
        "entityId": "",
        "data": "{\"message\":\"当前油烟/空气质量浓度:{{current}} ppm,设备应自动关闭!\",\"title\":\"设备控制\"}",
        "dataType": "json",
        "mergecontext": "",
        "queue": "none",
        "x": 1540,
        "y": 980,
        "wires": [
        "id": "7255edefed08d4fe",
        "name": "查询油烟机自动控制状态指示",
        "version": 2,
        "outputs": 2,
        "halt_if": "true",
        "halt_if_type": "bool",
        "entity_id": "binary_sensor.nodered_55a5cabe4e031a6a",
        "state_type": "habool",
                "value": "",
                "property": "data",
                "value": "",
        "x": 1260,
        "y": 760,
        "wires": [
                "03ec607eb7801fc3"
        "id": "983d6f01669809cd",
        "version": 2,
        "outputs": 2,
        "halt_if": "true",
                "value": "",
                "property": "data",
                "value": "",
        "x": 1260,
        "y": 1060,
        "wires": [
                "f9e7ae09d000adfa"
        "id": "96f4ac0a46cfa49b",
        "name": "启动背光板",
        "version": 3,
        "service_domain": "switch",
        "service": "turn_on",
        "entityId": "switch.you_yan_chuan_gan_qi_bei_guang_kong_zhi",
        "data": "",
        "dataType": "jsonata",
        "mergecontext": "",
        "queue": "none",
        "x": 670,
        "y": 680,
        "wires": [
        "id": "72bb77b5a3a0b0da",
        "name": "关闭背光板",
        "version": 3,
        "service": "turn_off",
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 970,
        "y": 620,
        "wires": [
        "id": "a65f5239c50bfbc0",
        "name": "背光板控制",
        "version": 3,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "switch.you_yan_chuan_gan_qi_bei_guang_kong_zhi",
        "state_type": "str",
        "haltifstate": "on",
        "outputs": 2,
        "for": "1",
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 120,
        "y": 640,
        "wires": [
                "72bb77b5a3a0b0da"
        "id": "32f5ec3c6cf8b4cf",
        "name": "关闭背光板",
        "version": 3,
        "data": "",
        "mergecontext": "",
        "queue": "none",
        "x": 670,
        "y": 800,
        "wires": [
        "id": "7fdac22db5ee6b02",
        "name": "厨房油烟机状态指示",
        "version": 3,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "binary_sensor.nodered_55a5cabe4e031a6a",
        "haltifstate": "true",
        "outputs": 2,
        "for": 0,
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 130,
        "y": 1140,
        "wires": [
                "8507f42368354dea"
                "e03e6ac38d6e004e"
        "id": "acb69f7d18961b7f",
        "type": "ha-device",
        "name": "开启油烟机",
        "version": 0,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "inputs": 1,
        "deviceType": "action",
        "device": "b392c6d5e437bd51177b6a18e7a2f13f",
        "event": {
            "type": "turn_on",
            "device_id": "b392c6d5e437bd51177b6a18e7a2f13f",
            "entity_id": "switch.6ca6b4d7aa5d6528844x9d",
            "domain": "switch"
        "capabilities": [],
        "x": 660,
        "y": 1060,
        "wires": [
        "id": "1491e89a90f76316",
        "name": "关闭油烟机",
        "version": 0,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "inputs": 1,
        "event": {
            "type": "turn_off",
            "domain": "switch"
        "capabilities": [],
        "x": 660,
        "y": 1140,
        "wires": [
        "id": "8507f42368354dea",
        "name": "是否进行自动控制",
        "version": 2,
        "outputs": 2,
        "halt_if": "true",
        "entity_id": "input_boolean.zi_dong_kong_zhi_you_yan_ji",
                "value": "",
                "property": "data",
                "value": "",
        "x": 360,
        "y": 1100,
        "wires": [
                "acb69f7d18961b7f"
        "id": "e03e6ac38d6e004e",
        "name": "是否进行自动控制",
        "version": 2,
        "outputs": 2,
        "halt_if": "true",
                "value": "",
                "property": "data",
                "value": "",
        "x": 350,
        "y": 1200,
        "wires": [
                "1491e89a90f76316"
        "id": "882ba4576c867324",
        "name": "自动控制状态改变",
        "version": 3,
        "haConfig": [
                "property": "name",
                "value": ""
                "property": "icon",
                "value": ""
        "entityidfilter": "input_boolean.zi_dong_kong_zhi_you_yan_ji",
        "haltifstate": "false",
        "outputs": 2,
        "for": 0,
        "forType": "num",
                "value": "",
                "property": "data",
                "value": "",
                "value": "",
        "x": 130,
        "y": 1340,
        "wires": [
                "1491e89a90f76316"
        "id": "6170f2b1.2e2f14",
        "type": "mqtt-broker",
        "name": "HomeAssistant",
        "broker": "[fc00:470:f1cd::ff00]",
        "port": "1883",
        "clientid": "",
        "usetls": false,
        "protocolVersion": "4",
        "keepalive": "60",
        "cleansession": true,
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": "",
        "birthMsg": {},
        "closeTopic": "",
        "closeQos": "0",
        "closePayload": "",
        "closeMsg": {},
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "willMsg": {},
        "sessionExpiry": ""
        "id": "3c87f99d.1fa9b6",
        "type": "server",
        "name": "Home Assistant",
        "version": 1,
        "legacy": false,
        "addon": false,
        "connectionDelay": true,
        "cacheJson": true
github
https://github.com/jack9603301/lampblack-alert
注意
我们用的洞洞版,其PCB设计未经实际测试
参与人数 2金钱 +40 HASS币 +20 收起 理由
+ 20 + 20 厉害了word楼主!
jyz_0501 + 20 墙都不扶,就服楼主!
3万
发表于 2021-8-19 21:58:53 | 显示全部楼层
我的斐迅的m1中的pm2.5在有油烟时会数值超高,之前就是用放在餐厅(紧对着厨房门)的这个提醒要关厨房门和开油烟机。
我就是六神
活跃会员教程狂人灌水之王
发表于 2021-8-20 00:57:39 | 显示全部楼层
膜拜大佬! 看得我头昏眼花~
发表于 2021-8-20 10:18:46 | 显示全部楼层
触控的怎么焊接呢
发表于 2021-8-20 10:36:25 | 显示全部楼层
这个好,谢谢分享
发表于 2021-8-20 11:10:37 | 显示全部楼层
没看到懂,就是好牛P,
发表于 2021-8-20 12:37:16 | 显示全部楼层
技术牛!!不过,最实用还是直接开燃气灶就开油烟机,关燃气灶后延时关油烟机
发表于 2021-8-20 15:33:34 | 显示全部楼层
好奇楼主多大..
来2张图片看看实物啊~~
发表于 2021-8-20 16:48:10 | 显示全部楼层
zsqduke 发表于 2021-8-20 12:37
技术牛!!不过,最实用还是直接开燃气灶就开油烟机,关燃气灶后延时关油烟机 ...
可以在点火旋钮里加霍尔开关之类的,直连到油烟机上。
我不生产技术,我只是技术的搬运工。
发表于 2021-8-20 19:53:35 | 显示全部楼层
很有成就感,有钱了再给你爸换集成灶,那玩意开火强制开排烟
GMT+8, 2025-9-13 03:17 , Processed in 0.475675 second(s), 7 queries , MemCached On.
