查看: 22247|回复: 10
[基础教程] ESPHOME 红外发射和接收配合MQTT
发表于 2021-8-10 12:25:12 | 显示全部楼层 |阅读模式
总体框架是这样的1,想要发送红外的时候,往MQTT 指定topic publish,然后ESPHOME会负责把内容发出去。
2,ESPHOME接受到遥控器的数据后,负责把数据转发到MQTT。
这样弄好之后,想要做什么都是通过MQTT自动化完成。
如下是ESPHOME的主要配置。
text_sensor:
  - platform: mqtt_subscribe
    name: "nec to send"
    topic: epshome32/sendnec
    on_value:
      then:
        remote_transmitter.transmit_nec:
          address: !lambda |-
            unsigned int addr;
            unsigned int command;
            sscanf(x.c_str(),"%x:%x",&addr,&command);
            ESP_LOGI("main", "NEC:0x%x:0x%x", addr,command);
            return addr;
          command: !lambda |-
            unsigned int addr;
            return command;
    name: "pana to send"
    topic: epshome32/sendpan
    on_value:
      then:
        remote_transmitter.transmit_panasonic:
          address: !lambda |-
            unsigned int addr;
            unsigned long command;
            ESP_LOGI("main", "PANA:0x%x:0x%x", addr,command);
            return addr;
          command: !lambda |-
            unsigned int addr;
            return command;
    name: "sam to send"
    topic: epshome32/sendsam
    on_value:
      then:
        remote_transmitter.transmit_samsung:
          data: !lambda |-
            unsigned long data;
            sscanf(x.c_str(),"%x",&data);
            ESP_LOGI("main", "SAM:0x%x", data);
            return data;
remote_transmitter:
  pin: GPIO21
  carrier_duty_percent: 50%
remote_receiver:
  pin:
    number: GPIO23
    inverted: True
#    mode: INPUT_PULLUP
  dump: all
  on_nec:
    then:
    - mqtt.publish:
        topic: esphome32/senso/ir
        payload: !lambda |-
          char temp[20];
          sprintf(temp, "%d:%d", x.address, x.command);
          ESP_LOGI("main", "rcv nec: %s", temp);
          return temp;
  on_panasonic:
    then:
    - mqtt.publish:
        payload: !lambda |-
          char temp[20];
          ESP_LOGI("main", "rcv pan: %s", temp);
          return temp;
  on_sony:
    then:
    - mqtt.publish:
        payload: !lambda |-
          char temp[20];
          sprintf(temp, "%d:%d", x.data, x.nbits);
          ESP_LOGI("main", "rcv sony: %s", temp);
          return temp;
  on_jvc:
    then:
    - mqtt.publish:
        payload: !lambda |-
          char temp[20];
          sprintf(temp, "%d", x.data);
          ESP_LOGI("main", "rcv jvc: %s", temp);
          return temp;
  on_rc5:
    then:
    - mqtt.publish:
        payload: !lambda |-
          char temp[20];
          ESP_LOGI("main", "rcv rc5: %s", temp);
          return temp;
硬件链接可以参考这个
https://cdn.sparkfun.com/assets/ ... e395f6d42000000.jpg
https://learn.sparkfun.com/tutorials/ir-communication/all
佑桑
发表于 2021-8-10 13:04:11 | 显示全部楼层
使用 OpenMQTTGateway 是不是更簡單點
https://docs.openmqttgateway.com/
发表于 2021-8-10 13:11:22 | 显示全部楼层
待反馈吗?
发表于 2021-8-10 21:52:15 | 显示全部楼层
我觉得,使用ESPHOME的好处是可以结合更多的sensor和ble tracker等等在同一个板子上
发表于 2021-8-13 16:31:15 | 显示全部楼层
楼主,来个更详细的说明吧,之前买了小米的空调伴2    发现这玩意竟然没继电器,不能断电。想了一下这玩意可以自己做一个,继电器+红外发送就行了,。但它也有个好处,遥控器的开关和温度调整它也能接收到并更新APP上的状态
发表于 2021-10-28 13:23:30 | 显示全部楼层
谢谢分享
发表于 2022-6-20 08:53:48 | 显示全部楼层
这个有意思,现在DIY人体传感器,加个这玩意上去,又可以遥控房间红外设备了,66666
发表于 2022-6-20 09:14:02 来自手机 | 显示全部楼层
mark一下
发表于 2022-9-12 22:25:39 | 显示全部楼层
接收部分MQTT能收到按键信息了,请问里面的发射部分有什么作用?没明白原理。
epshome32/sendnec这个主题好像也没信息。
海鲜市场:jasona3
发表于 2023-3-23 08:57:02 | 显示全部楼层
留名学习
GMT+8, 2025-12-17 15:49 , Processed in 0.409044 second(s), 12 queries , MemCached On.
