楼主: linxianxin
[经验分享] 发现格力+的空调缺陷
发表于 2022-10-22 11:12:10 | 显示全部楼层
suifeng009 发表于 2022-10-21 00:00
- platform: gree
  host: 192.168.2.6
你是格力的什么空调?我加了这个集成,但是一直提示getkey超时。
发表于 2022-10-22 15:13:40 | 显示全部楼层
云锦 还一个啥得忘记  WIFI就可以接入
发表于 2022-10-22 20:38:53 | 显示全部楼层
2022-10-22 12:34:55.131 ERROR (MainThread) [homeassistant.components.climate] Error while setting up gree platform for climate
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 281, in _async_setup_platform
    await asyncio.shield(task)
  File "/usr/local/lib/python3.10/asyncio/coroutines.py", line 124, in coro
    res = func(*args, **kw)
  File "/config/custom_components/gree/climate.py", line 116, in async_setup_platform
    GreeClimate(hass, name, ip_addr, port, mac_addr, timeout, target_temp_step, temp_sensor_entity_id, lights_entity_id, xfan_entity_id, health_entity_id, powersave_entity_id, sleep_entity_id, eightdegheat_entity_id, air_entity_id, hvac_modes, fan_modes, swing_modes, encryption_key, uid)
  File "/config/custom_components/gree/climate.py", line 163, in __init__
    self._encryption_key = self.GetDeviceKey().encode("utf8")
  File "/config/custom_components/gree/climate.py", line 247, in GetDeviceKey
    return self.FetchResult(cipher, self._ip_addr, self._port, self._timeout, jsonPayloadToSend)['key']
  File "/config/custom_components/gree/climate.py", line 230, in FetchResult
    data, addr = clientSock.recvfrom(64000)
奇怪,我按照你的配置,也是提示获取key不到。云景、云恬应该没有差别的。可以把你的集成压缩一下放上来不?我试试。
发表于 2022-10-22 23:31:44 | 显示全部楼层
chenguy2022 发表于 2022-10-22 20:38
2022-10-22 12:34:55.131 ERROR (MainThread) [homeassistant.components.climate] Error while setting  ...
https://github.com/RobHofmann/HomeAssistant-GreeClimateComponent
发表于 2022-10-22 23:59:10 | 显示全部楼层
感谢,我也是用这个集成,下的是15 Jun 2022版本,一直添加不成功。请教下,你的集成是什么版本?
发表于 2022-10-23 00:06:19 | 显示全部楼层
chenguy2022 发表于 2022-10-22 23:59
感谢,我也是用这个集成,下的是15 Jun 2022版本,一直添加不成功。请教下,你的集成是什么版本? ...
直接HACS下载的~~~
发表于 2022-10-23 17:07:22 | 显示全部楼层
谢谢,试了HACS的集成,还是一样报错,哎。
发表于 2023-2-1 21:03:32 | 显示全部楼层
我猜前提条件是接入“格力+”APP,我的是京东的京致空调(京东与格力合作开的发空调),在“京东小家”APP可接入,但无法在“格力+”APP接入(虽然该APP提示可添加此款设备),与你出现了相同的情况。
按上述提示配置好configuration.yaml文件,但无法在设备与集成中找到配置好的“First AC”设备或实体。
jon 手机认证
发表于 2025-3-14 13:30:34 | 显示全部楼层
现在还是这样,有解决办法吗
 楼主| 发表于 2025-7-3 00:17:41 | 显示全部楼层
jon 发表于 2025-3-14 13:30
现在还是这样,有解决办法吗
没办法,这个问题是小米的问题,他们没更新红外
GMT+8, 2025-9-15 03:08 , Processed in 0.962208 second(s), 10 queries , MemCached On.
