查看: 6677|回复: 1
自动化的 action:下面能否再加条件?已解决
发表于 2021-6-26 10:27:45 | 显示全部楼层 |阅读模式
有人试过这种搞法么?我试了下,好像不行。
比如想实现一个功能,不知道还有其它啥好方法么?
门被打开-->发送通知,如果在X点-X7点时间内--->自动开灯
就是只要开门 就会发送通知,但是否开灯,由另外的条件决定。
行了,找到答案了,参考这个   ,之前写错了,所以不行
automation:
- alias: "Office at evening"
  trigger:
    - platform: state
      entity_id: sensor.office_occupancy
      to: "on"
  action:
    - service: notify.notify
      data:
        message: "Testing conditional actions"
    - condition: or                                     #后面就是执行中加判断,
      conditions:
        - condition: numeric_state
          entity_id: sun.sun
          attribute: elevation
          below: 4
        - condition: state
          entity_id: sensor.office_illuminance
          below: 10
    - service: scene.turn_on
      target:
        entity_id: scene.office_at_evening
智能家居&单板滑雪痴迷爱好者
发表于 2021-6-26 11:20:28 | 显示全部楼层
可以,看文档啊!
Conditions can also be part of an action. You can combine multiple service calls and conditions in a single action, and they will be processed in the order you put them in. If the result of a condition is false, the action will stop there so any service calls after that condition will not be executed.
参与人数 1金钱 +5 收起 理由
neoyang + 5
GMT+8, 2025-8-15 03:07 , Processed in 0.714335 second(s), 6 queries , MemCached On.
