楼主: froggyfly
[基础教程] Yeelight旋钮开关(无线、单火)接入homeassistant
 楼主| 发表于 2021-5-24 14:18:15 来自手机 | 显示全部楼层
Jerrylee 发表于 2021-5-24 14:01
虽然我没有该款遥控器 还是感谢楼主
安装比较麻烦,不然是挺想帮老家搞一组
这款本体浴霸已经可以接入了的,遥控器要说拿来单独使用吧好像意义不大,上面有字的,单卖50块。
大佬们比较追求完美吧
发表于 2021-5-24 17:22:46 | 显示全部楼层
大佬们 ...
我是说安装浴霸 不是遥控器
确实也不知道大神增加那款支援的用途....
发表于 2021-5-24 17:57:06 | 显示全部楼层
大佬们 ...
我有几个遥控器是原来灯配的,但是基本上没用过,谁没事开个灯到处找遥控器
现在能接HA就直接跟灯解绑了,然后自己打印图案贴到按键上
 楼主| 发表于 2021-5-24 22:32:39 来自手机 | 显示全部楼层
现在能接HA就直接跟灯解绑了 ...
长条的那几个可以用用,我也有两
发表于 2021-5-24 22:56:41 | 显示全部楼层
这个终于可以用了。写了个状态解析的NR流
[{"id":"6ed68d92.f35f64","type":"server-state-changed","z":"1035aa96.933df5","name":"旋钮","server":"6a1fbd9f.652854","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.ble_dimmer_f82152251c3c8e7","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"x":390,"y":780,"wires":[["eefb58a3.9871c8"]]},{"id":"eefb58a3.9871c8","type":"switch","z":"1035aa96.933df5","name":"","property":"payload","propertyType":"msg","rules":[{"t":"regex","v":"short press \\d+ x","vt":"str","case":true},{"t":"regex","v":"rotate left \\d+ step\\(s\\)","vt":"str","case":true},{"t":"regex","v":"rotate right \\d+ step\\(s\\)","vt":"str","case":true},{"t":"regex","v":"long press \\d seconds","vt":"str","case":true},{"t":"regex","v":"rotate left \\(pressed\\) \\d+ step\\(s\\)","vt":"str","case":true},{"t":"regex","v":"rotate right \\(pressed\\) \\d+ step\\(s\\)","vt":"str","case":true}],"checkall":"true","repair":false,"outputs":6,"x":510,"y":780,"wires":[["16d6c45a.c2d74c"],["44d6561.73d3ca8"],["b8cba19a.4bf82"],["555347e4.97daf8"],["a087439d.51da8"],["2bd18589.5ade8a"]]},{"id":"7c39a569.ec5f7c","type":"debug","z":"1035aa96.933df5","name":"左旋值","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":810,"y":720,"wires":[]},{"id":"44d6561.73d3ca8","type":"change","z":"1035aa96.933df5","name":"左旋","rules":[{"t":"set","p":"payload","pt":"msg","to":"$split($.payload, " ", limit)[2]\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":720,"wires":[["7c39a569.ec5f7c"]]},{"id":"c71ff511.594e18","type":"debug","z":"1035aa96.933df5","name":"右旋值","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":810,"y":760,"wires":[]},{"id":"b8cba19a.4bf82","type":"change","z":"1035aa96.933df5","name":"右旋","rules":[{"t":"set","p":"payload","pt":"msg","to":"$split($.payload, " ", limit)[2]\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":760,"wires":[["c71ff511.594e18"]]},{"id":"cef763b.a21dba","type":"debug","z":"1035aa96.933df5","name":"点击数","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":810,"y":680,"wires":[]},{"id":"16d6c45a.c2d74c","type":"change","z":"1035aa96.933df5","name":"点击","rules":[{"t":"set","p":"payload","pt":"msg","to":"$split($.payload, " ", limit)[2]\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":680,"wires":[["cef763b.a21dba"]]},{"id":"d2bede16.323","type":"debug","z":"1035aa96.933df5","name":"长按秒","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":810,"y":800,"wires":[]},{"id":"555347e4.97daf8","type":"change","z":"1035aa96.933df5","name":"长按","rules":[{"t":"set","p":"payload","pt":"msg","to":"$split($.payload, " ", limit)[2]\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":800,"wires":[["d2bede16.323"]]},{"id":"e57c9bc.d393f68","type":"debug","z":"1035aa96.933df5","name":"左旋值","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":810,"y":840,"wires":[]},{"id":"a087439d.51da8","type":"change","z":"1035aa96.933df5","name":"压左旋","rules":[{"t":"set","p":"payload","pt":"msg","to":"$split($.payload, " ", limit)[3]\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":840,"wires":[["e57c9bc.d393f68"]]},{"id":"4f15e9c4.3b5358","type":"debug","z":"1035aa96.933df5","name":"右旋值","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":810,"y":880,"wires":[]},{"id":"2bd18589.5ade8a","type":"change","z":"1035aa96.933df5","name":"压右旋","rules":[{"t":"set","p":"payload","pt":"msg","to":"$split($.payload, " ", limit)[3]\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":690,"y":880,"wires":[["4f15e9c4.3b5358"]]},{"id":"6a1fbd9f.652854","type":"server","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":false,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
 楼主| 发表于 2021-5-25 00:19:38 来自手机 | 显示全部楼层
感谢分享,我还没来得及写完,就直接拿来用啦
 楼主| 发表于 2021-5-25 00:23:02 来自手机 | 显示全部楼层
现在能接HA就直接跟灯解绑了 ...
那些长条遥控器算是废物利用了,哈哈,好用
 楼主| 发表于 2021-5-25 00:26:57 | 显示全部楼层
Jerrylee 发表于 2021-5-24 17:22
我是说安装浴霸 不是遥控器
大佬给的那个script我按不上拒绝连接,这Linux我一点不会用,抓瞎了,改版app还扫不到浴霸遥控器,,,老哥你有时间的话私我个微信教教我怎么用其他办法弄到key?
发表于 2021-5-25 01:06:46 | 显示全部楼层
froggyfly 发表于 2021-5-25 00:26
大佬给的那个script我按不上拒绝连接,这Linux我一点不会用,抓瞎了,改版app还扫不到浴霸遥控器,,,老 ...
没看到这里 我在那边写给你步骤了
不行的话再私讯微信讨论
发表于 2021-5-25 15:25:52 | 显示全部楼层
多模 AlexxiT 大神 刚刚也把 01/07/08 加入支援了
GMT+8, 2025-9-18 03:12 , Processed in 0.350874 second(s), 8 queries , MemCached On.
