查看: 24331|回复: 10
[求助] 请教下 新版ha的风扇fan元件怎么写了
发表于 2021-5-4 13:16:05 | 显示全部楼层 |阅读模式
  - platform: template
    sensors:
      fan_speeds:
        value_template: >
          {% if states('switch.fanlow') == 'unavailable' %}
            unavailable
          {% elif states('switch.fanfast') == 'on' %}
            高速
          {% elif states('switch.fanmid') == 'on' %}
            中速
          {% elif states('switch.fanlow') == 'on' %}
            低速
          {% else %}
            关闭
          {% endif %}
fan:        #建立一个fan元件
    fans:
      fan_speed:
        value_template: >
          {% if is_state("sensor.fan_speeds", "unavailable") %}
            off
          {% elif states('sensor.fan_speeds') == '关闭' %}
            off
          {% else %}
            on
          {% endif %}
        speed_template: '{{ states("sensor.fan_speeds") }}'
        turn_on:
          - service: switch.turn_on
            entity_id: switch.fanlow
        turn_off:
          - service: switch.turn_off
            entity_id: switch.fanmid
            entity_id: switch.fanfast
        set_speed:
            data_template:
              entity_id: >
                {% if speed == '低速' %}
                  switch.fanlow
                {% elif speed == '中速' %}
                  switch.fanmid
                {% elif speed == '高速' %}
                  switch.fanfast
                {% elif speed == '关闭' %}
                  switch.off
                {% endif %}
        speeds:
          - '关闭'
          - '低速'
          - '中速'
          - '高速'
上面是原本的设置,更新ha后 这个实体没有了 关闭 低俗 中速 高速等选项调节了
 楼主| 发表于 2021-5-4 15:22:21 | 显示全部楼层
新版使用百分比了 找下外国的配置修改下 百分比设置3个档位 触发脚本打开
configuration.yaml
    sensors:
      fan_speeds:
        value_template: >
            unavailable
            100
            66
          {% else %}
            Off
          {% endif %}
fan:        #建立一个fan元件
    fans:
      fan_speed:
        value_template: >
            off
            off
          {% else %}
            on
          {% endif %}
        percentage_template: "{{ states('sensor.fan_speeds') }}"
        turn_on:
        turn_off:
        set_percentage:
          service: >
            {% if percentage == 33 %}
              script.luodi_fan_percentage_33
            {% elif percentage == 66 %}
              script.luodi_fan_percentage_66
            {% elif percentage == 100 %}
              script.luodi_fan_percentage_100
            {% else %}
              script.dining_fan_off
            {% endif %}
        speed_count: 3
        speeds:
          - '关闭'
          - '低速'
          - '中速'
          - '高速'
secrets.yaml
luodi_fan_off:
  sequence:
    - service: fan.turn_off
      data: {}
      entity_id: fan.fan_speed
luodi_fan_percentage_33:
  sequence:
      data: {}
  mode: single
luodi_fan_percentage_66:
  sequence:
      data: {}
  mode: single
luodi_fan_percentage_100:
  sequence:
      data: {}
  mode: single
27hh
教程狂人论坛风云人物
发表于 2021-5-4 20:48:39 | 显示全部楼层
高速
            中速
            低速
          {% else %}
            关闭
改成
high
            medium
            low
          {% else %}
            off
HA以前允许风扇速度名称为任意文字的,最新版本只允许low medium high off和数字百分比。
发表于 2021-5-4 21:04:10 | 显示全部楼层
现在也能能用文字,需要用preset_mode,参看下官方文档
我就是六神
活跃会员教程狂人灌水之王
发表于 2021-5-5 09:13:53 | 显示全部楼层
楼上的请收下膝盖
发表于 2021-5-5 13:55:18 | 显示全部楼层
受教了      。
 楼主| 发表于 2021-5-5 18:23:16 | 显示全部楼层
谢谢 昨天用homekit控制用不了档位 奇怪了原来新ha改了
发表于 2021-6-29 13:54:14 | 显示全部楼层
学习学习,搞了几天搞到人都晕了,原来以前教程都不适用了
发表于 2021-6-29 14:52:25 | 显示全部楼层
感谢楼上各位大神,homekit终于可以正常使用了
发表于 2021-7-25 09:53:17 | 显示全部楼层
nr调用ha里面风扇风速,怎么配置nr。 f34d1f33cb2bf2957c921ab6dcf75bb.png ffc72ee4eb0c872dadd525e14dc859e.png
GMT+8, 2025-6-28 12:01 , Processed in 1.124599 second(s), 27 queries .
