查看: 3504|回复: 1
【学习记录】ESPHOME 点亮 NODEMCU 的2个板灯 还有D5接了个DHT
发表于 2021-4-21 20:11:54 | 显示全部楼层 |阅读模式
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "wifi账号"
  password: "密码"
  ap:
    ssid: "Diy-Nodemcu-Temp"
    password: "密码"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
time:
  - platform: homeassistant
switch:
  - platform: restart
    name: "Reboot the light"
#控制2路灯
output:
  - platform: gpio
    pin: GPIO2
  - platform: gpio
    pin: GPIO16
light:
  - platform: binary
    output: relay
  - platform: binary
    output: relay2
#暂时没用,还没物理面板
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      mode: INPUT_PULLUP
      inverted: True
    name: "light_home Physical Switch Sensor"
    on_press:
      then:
        - light.turn_on: light_home
    on_release:
      then:
        - light.turn_off: light_home
    on_multi_click:
    - timing:
        - ON for at most 0.5s
        - OFF for at most 0.5s
        - OFF for at least 0.2s
      then:
        - switch.turn_on: light_home_restart
#开启网页端
web_server:
  port: 80
  - platform: dht
    pin: D5
    temperature:
    humidity:
    model: DHT11
    update_interval: 10s
参与人数 1金钱 +5 收起 理由
sorrypqa + 5 感谢楼主分享!
发表于 2022-6-12 20:23:09 | 显示全部楼层
不错,学习一下,谢谢分享!
GMT+8, 2025-7-9 10:40 , Processed in 0.114454 second(s), 9 queries , MemCached On.
