楼主: firelion
[业界动态] 多模网关Xiaomi Gateway 3插件支持zigbee2mqtt了
发表于 2021-4-2 12:20:45 | 显示全部楼层
firelion 发表于 2021-4-2 12:09
2代多功能网关?也有zigbee2mqtt么?
没有,不支持2代
Important: This component does not work with:
  • Xiaomi Gateway 2 (DGNWG02LM, lumi.gateway.v3) - use [color=var(--color-text-link)]this component
  • Xiaomi Gateway EU (DGNWG05LM, lumi.gateway.mieu01)
发表于 2021-4-2 13:38:54 | 显示全部楼层
打错了数字
发表于 2021-4-29 23:58:29 | 显示全部楼层
zhenxiwen 发表于 2021-4-2 12:19
现在不需要重新刷写zigbee模块固件,原生固件就行而且可以升级,模式切换只需在miaomigaway3设置中就可以 ...
请问知道切换zigbee2mqtt模式后,在z2m里面报错是什么问题导致的吗?
[15:49:37] INFO: Handing over control to Zigbee2mqtt Core ...
> [email protected] start /app
> node index.js
Zigbee2MQTT:error 2021-04-29 15:50:05: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2021-04-29 15:50:05: Failed to start zigbee
Zigbee2MQTT:error 2021-04-29 15:50:05: Exiting...
Zigbee2MQTT:error 2021-04-29 15:50:05: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:94:31)
    at Generator.throw (<anonymous>)
    at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2021-04-29T15_50_05_456Z-debug.log
[15:50:06] INFO: Handing over control to Zigbee2mqtt Core ...
发表于 2023-3-7 23:17:09 | 显示全部楼层
现在才开始研究这个,但是最新插件和加载项,Xiaomi Gateway 3和Mosquitto broker正常安装,到了Zigbee2Mqtt,死活启动不了,Zigbee2Mqtt中日志显示Error while starting zigbee-herdsman,配置了serial:
  port: tcp://{gatewayIP}:8888
  adapter: ezsp,还是不行
GMT+8, 2025-9-10 06:25 , Processed in 0.152766 second(s), 9 queries , MemCached On.
