查看: 163224|回复: 165
[业界动态] 重磅, 小米多模网关全系列固件破解telnet, 免拆机
发表于 2021-2-24 16:09:09 | 显示全部楼层 |阅读模式
引用 15楼 jonceli的经验
分了四个步骤,
1、hacs安装xiaomi gateway3 重启ha;
2、集成中配置xiaomi gateway3设置自己的小米用户名和密码;
3、集成中配置xiaomi gateway3添加小米多摸网关,此时应该在步骤2中找到了该网关以及它的token数据;
4、在配置选项的“open telnet command"栏中输入“{"method":"set_ip_info","params":{"ssid":"\"\"","pswd":"123123 ; passwd -d admin ; echo enable > /sys/class/tty/tty/enable; telnetd"}}”然后提交,稍候片刻即可
为前几个月拆机焊接破解的哥们默哀5秒钟
原文链接: https://gist.github.com/zvldz/1bd6b21539f84339c218f9427e022709
# Soft hack to open telnet
You need gateway 3(mgl03) connected to MiHome. And also ip and gateway token.
### 1 way (recommended)
Via [XiaomiGateway3](https://github.com/AlexxIT/XiaomiGateway3) component.
You must input in the 'Open Telnet command' field:
{"method":"set_ip_info","params":{"ssid":"""","pswd":"123123 ; passwd -d admin ; echo enable > /sys/class/tty/tty/enable; telnetd"}}
### 2 way (recommended if not using Home Assistant)
php-miio (https://github.com/skysilver-lab/php-miio)
You may need to change id.
```sh
php miio-cli.php --ip GW_IP --token GW_TOKEN --sendcmd '{"id":123,"method":"set_ip_info","params":{"ssid":"""","pswd":"123123 ; passwd -d admin ; echo enable > /sys/class/tty/tty/enable; telnetd"}}'
### 3 way (maybe problem with sequence id)
python-miio (https://github.com/rytilahti/python-miio)
```sh
miiocli device --ip GW_IP --token GW_TOKEN raw_command set_ip_info '{"ssid":"""","pswd":"123123 ; passwd -d admin ; echo enable > /sys/class/tty/tty/enable; telnetd"}'
After opening telnet, it is better to install custom firmware.
Read here:
https://gist.github.com/zvldz/b40b4873e3c4c1a64ac536e8ce5dbdad#the-easy-way
This method should also work with:
* lumi.gateway.mgl03 - Mi Smart Home Hub
* lumi.gateway.acn01 - Aqara Hub M1S CN
* lumi.gateway.aeu01 - Aqara Hub M1S EU
* lumi.aircondition.acn05 - Aqara Air Conditioning Controller P3
* lumi.gateway.sacn01 - Smart USB Wall Outlet Hub
I am not author, I just tested and improved and published.
参与人数 3金钱 +46 HASS币 +10 收起 理由
wormshow + 10 感谢楼主分享!
+ 20 + 10 感谢楼主分享!
eric + 16 感谢楼主分享!
发表于 2021-2-24 16:09:59 | 显示全部楼层
意味着什么呢
 楼主| 发表于 2021-2-24 16:10:56 | 显示全部楼层
意味着不用再拆机器焊接了, 前几个月拆机破解的哥们要哭了
eric 手机认证
卓越贡献
发表于 2021-2-24 16:24:15 | 显示全部楼层
拆机还好吧!!感谢分享!!
发表于 2021-2-24 16:30:11 | 显示全部楼层
虽然我拆机没怎么损坏外观, 但我还是吐了
感谢分享!
发表于 2021-2-24 17:44:26 | 显示全部楼层
厉害了大神。
貌似有人拆机搞废了的。
我不生产技术,我只是技术的搬运工。
发表于 2021-2-24 20:44:07 | 显示全部楼层
怎么操作啊
发表于 2021-2-24 21:22:17 | 显示全部楼层
汗,上个月拆了两台了,好在都没变砖
发表于 2021-2-24 21:40:00 | 显示全部楼层
原文链接无法打开,是不是要梯子啊
发表于 2021-2-24 21:53:40 来自手机 | 显示全部楼层
我哭了,周日刚刚撬壳的时候,瑞士军刀在手上划了一道又长又深的口子,血都止不住。。。
参与人数 1金钱 +1 收起 理由
uavana + 1 给你回点血, 还好我有两个, 只有一个需要破.
GMT+8, 2025-12-16 15:43 , Processed in 0.852121 second(s), 12 queries , MemCached On.
