楼主: 27hh
[进阶教程] Xiaomi MIoT - 小米米家设备全自动通用接入插件,无需配置文件
发表于 2022-3-16 22:33:16 | 显示全部楼层
xiaomi_miot_raw.speak_text突然调用不了了,是不是小米那边改了东西了?
发表于 2022-3-16 20:37:27 | 显示全部楼层
实测群晖,DOCKER版本:
Home Assistant 2022.4.0.dev20220315
无法使用报错:
Logger: homeassistant.setup
Source: setup.py:298
First occurred: 21:44:13 (6 occurrences)
Last logged: 21:44:13
Unable to prepare setup for platform xiaomi_miot.binary_sensor: Platform not found (cannot import name 'SPEED_OFF' from 'homeassistant.components.fan' (/usr/src/homeassistant/homeassistant/components/fan/__init__.py)).
Unable to prepare setup for platform xiaomi_miot.climate: Platform not found (cannot import name 'SPEED_OFF' from 'homeassistant.components.fan' (/usr/src/homeassistant/homeassistant/components/fan/__init__.py)).
Unable to prepare setup for platform xiaomi_miot.cover: Platform not found (cannot import name 'SPEED_OFF' from 'homeassistant.components.fan' (/usr/src/homeassistant/homeassistant/components/fan/__init__.py)).
Unable to prepare setup for platform xiaomi_miot.humidifier: Platform not found (cannot import name 'SPEED_OFF' from 'homeassistant.components.fan' (/usr/src/homeassistant/homeassistant/components/fan/__init__.py)).
Unable to prepare setup for platform xiaomi_miot.device_tracker: Platform not found (cannot import name 'SPEED_OFF' from 'homeassistant.components.fan' (/usr/src/homeassistant/homeassistant/components/fan/__init__.py)).
发表于 2022-3-11 17:32:10 | 显示全部楼层
如果选择自动,似乎默认是云端的,能不能默认本地(如果可以telnet),另外通过这种方式网关功能会少很多,没有对Zigbee的相关功能(比如配对).
发表于 2022-3-8 14:04:05 | 显示全部楼层
好东西了,对新手来说太友好了
发表于 2022-3-2 10:43:00 | 显示全部楼层
感谢楼主大神
发表于 2022-3-2 10:07:20 | 显示全部楼层
为啥我用了这个xiaomi MIoT都是无效的人体传感器,但是用auto就能正常
发表于 2022-2-24 17:34:49 | 显示全部楼层
已经配置成功,感谢大神!!!!
发表于 2022-2-22 13:05:36 | 显示全部楼层
非常感谢LZ,正在尝试
hxin
发表于 2022-2-18 00:17:08 | 显示全部楼层
此法可行,测试成功,只是反馈延时太大……应该不是家里网络问题,而是米家服务器转发延时问题
发表于 2022-2-17 23:13:47 | 显示全部楼层
GMT+8, 2025-9-17 03:11 , Processed in 1.121586 second(s), 14 queries , MemCached On.
