楼主: 27hh
[进阶教程] Xiaomi MIoT - 小米米家设备全自动通用接入插件,无需配置文件
发表于 2021-1-24 22:54:17 | 显示全部楼层
云米的洗衣机  不管是用 miio_raw 还是 mito_raw 都接不进去  viomi.washer.u2 脑壳疼
请输入设备model:viomi.washer.u2
已发现以下设备
序号            model             urn
1       viomi.washer.u2 urn:miot-spec-v2:device:washer:0000A01F:viomi-u2:1
设备描述:Washer
设备属性:
siid 1: Device Information
   piid 1: Device Manufacturer 可读取
      数据类型:string
   piid 2: Device Model 可读取
      数据类型:string
   piid 3: Device Serial Number 可读取
      数据类型:string
   piid 4: Current Firmware Version 可读取
      数据类型:string
siid 2: Washer
   piid 1: Mode 可读取 可控制
      数据类型:uint8
      取值范围:
         0: Gold Wash
         1: Shirt
         2: Silk
         3: Drum Clean
         4: Cotton
         5: Jeans
         6: Color Protection
         7: Soak Wash
         8: Super Quick
         9: Wool
         10: Rinse Spin
         11: Boiling
         12: Heavy Wash
         13: Down Coat
         14: Spin
         15: Dry
   piid 2: Left Time 可读取
      数据类型:uint32
      取值范围:[0, 65535, 1]
   piid 3: Status 可读取
      数据类型:uint8
      取值范围:
         1: Off
         2: Idle
         3: Check
         4: Check Paused
         5: Delay
         6: Soak
         7: Soak Paused
         8: Wash
         9: Wash Paused
         10: Rinse
         11: Rinse Paused
         12: Spin
         13: Spin Paused
         14: Sterilization
         15: Sterilization Paused
         16: Dry
         17: Dry Paused
         18: Completed
         19: Cool
         20: Anti-wrinkling
         21: Please Taking
         22: Ending
         23: Cleaning
         24: Prepare
         25: Prepare Paused
siid 3: Physical Control Locked
   piid 1: Physical Control Locked 可读取 可控制
      数据类型:bool
发表于 2021-1-24 21:22:19 | 显示全部楼层
试试只用摄像头的开关功能也不行
switch:
  - platform: xiaomi_miot_raw       #此部分为固定
    host: 192.168.0.162             #设备 IP
    token: 3434596b4******* #设备 token
    mapping:
      switch_status:                #开关类实体必须有这一项,用于读取和控制开关状态
        siid: 2
        piid: 1
    params:                         #params对应上面的mapping,用于指定该项的详细信息
      switch_status:                #对应上面的switch_status,即开/关时分别应该是什么状态
        power_on: True
        power_off: False
提示:
Logger: custom_components.xiaomi_miot_raw
Source: custom_components/xiaomi_miot_raw/__init__.py:140
Integration: xiaomi_miot_raw (documentation, issues)
First occurred: 下午9:14:50 (1 occurrences)
Last logged: 下午9:14:50
Got exception while fetching 摄像头 's state: No response from the device
Logger: homeassistant.components.switch
Source: custom_components/xiaomi_miot_raw/__init__.py:174
Integration: 开关 (documentation, issues)
xiaomi_miot_raw: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 359, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 466, in async_device_update
    await task
  File "/config/custom_components/xiaomi_miot_raw/__init__.py", line 174, in async_update
    state = self._state_attrs['switch_status']
KeyError: 'switch_status'
发表于 2021-1-24 21:17:15 | 显示全部楼层
学习到了,太有帮助了
发表于 2021-1-24 21:13:22 | 显示全部楼层
Model: chuangmi.camera.ipc013
不支持我的米家小白青春版摄像头,这个摄像头一直无解。希望楼主能支持,谢谢!
        "type": "urn:miot-spec-v2:device:camera:0000A01C:chuangmi-ipc013:1",
        "description": "Camera",
        "services": [{
                "iid": 1,
                "type": "urn:miot-spec-v2:service:device-information:00007801:chuangmi-ipc013:1",
                "description": "Device Information",
                "properties": [{
                        "iid": 1,
                        "type": "urn:miot-spec-v2:property:manufacturer:00000001:chuangmi-ipc013:1",
                        "description": "Device Manufacturer",
                        "format": "string",
                        "access": ["read"]
                        "iid": 2,
                        "type": "urn:miot-spec-v2:property:model:00000002:chuangmi-ipc013:1",
                        "description": "Device Model",
                        "format": "string",
                        "access": ["read"]
                        "iid": 3,
                        "type": "urn:miot-spec-v2:property:serial-number:00000003:chuangmi-ipc013:1",
                        "description": "Device Serial Number",
                        "format": "string",
                        "access": ["read"]
                        "iid": 4,
                        "type": "urn:miot-spec-v2:property:firmware-revision:00000005:chuangmi-ipc013:1",
                        "description": "Current Firmware Version",
                        "format": "string",
                        "access": ["read"]
                "iid": 2,
                "type": "urn:miot-spec-v2:service:camera-control:0000782F:chuangmi-ipc013:1",
                "description": "Camera Control",
                "properties": [{
                        "iid": 1,
                        "type": "urn:miot-spec-v2:propertyn:00000006:chuangmi-ipc013:1",
                        "description": "Switch Status",
                        "format": "bool",
                        "access": ["read", "write", "notify"]
                        "iid": 2,
                        "type": "urn:miot-spec-v2:property:image-rollover:00000058:chuangmi-ipc013:1",
                        "description": "Image Rollover",
                        "format": "uint16",
                        "access": ["read", "write"],
                        "unit": "arcdegrees",
                        "value-range": [0, 180, 180]
                        "iid": 3,
                        "type": "urn:miot-spec-v2:property:night-shot:00000057:chuangmi-ipc013:1",
                        "description": "Night Shot",
                        "format": "uint8",
                        "value-list": [{
                                "value": 0,
                                "description": "Auto"
                                "value": 1,
                                "description": "Off"
                                "value": 2,
                                "description": "On"
                "iid": 3,
                "type": "urn:miot-spec-v2:service:p2p-stream:00007881:chuangmi-ipc013:1",
                "description": "2P Stream",
                "actions": [{
                        "iid": 1,
                        "type": "urn:miot-spec-v2:action:start-p2p-stream:00002839:chuangmi-ipc013:1",
                        "description": "Start P2P Stream",
                        "in": [],
                        "out": []
                        "iid": 2,
                        "type": "urn:miot-spec-v2:action:stop-stream:00002822:chuangmi-ipc013:1",
                        "description": "Stop Camera Stream",
                        "in": [],
                        "out": []
发表于 2021-1-24 21:13:09 | 显示全部楼层
实体出来了,获取不了数据呢?楼主帮看看那里写错了?
发表于 2021-1-24 21:11:31 | 显示全部楼层
ModuleNotFoundError: No module named 'custom_components.xiaomi_miot_raw.camera'
请输入设备model:chuangmi.camera.ipc013
已发现以下设备
序号                model                   urn
1        chuangmi.camera.ipc013d        urn:miot-spec-v2:device:camera:0000A01C:chuangmi-ipc013d:1
2        chuangmi.camera.ipc013        urn:miot-spec-v2:device:camera:0000A01C:chuangmi-ipc013:1
请确认哪个是你的设备,输入序号:2
设备描述:Camera
设备属性:
      数据类型:string
      数据类型:string
      数据类型:string
      数据类型:string
siid 2: Camera Control
   piid 1: Switch Status 可读取 可控制
      数据类型:bool
   piid 2: Image Rollover 可读取 可控制
      数据类型:uint16
      取值范围:[0, 180, 180]
   piid 3: Night Shot 可读取 可控制
      数据类型:uint8
      取值范围:
         0: Auto
         1: Off
         2: On
siid 3: P2P Stream
  File "autoconfig.py", line 58, in <module>
    deviceinfo(r)
  File "autoconfig.py", line 12, in deviceinfo
    for p in s['properties']:
KeyError: 'properties'
发表于 2021-1-24 20:01:28 | 显示全部楼层
27hh 发表于 2021-1-24 19:45
空调伴侣已经有现成的插件了,净水器不知道你需要什么功能,可以通过传感器和开关接入;扫地机后期会支持 ...
原有空调伴侣插件在用,还想统一用moit接入控制呢。
我的扫地机 ,
NAME:  viomi Alpha 1A
MODEL:  viomi.vacuum.v17
27hh
教程狂人论坛风云人物
 楼主| 发表于 2021-1-24 19:47:23 | 显示全部楼层
xeyesen 发表于 2021-1-24 14:35
gosund cp1能接入了?
gosund cp1从这个插件发布之起就支持
27hh
教程狂人论坛风云人物
 楼主| 发表于 2021-1-24 19:46:55 | 显示全部楼层
dscao 发表于 2021-1-24 14:28
刚刚试了,问题是新版本数据内容进行了加密,date部分拿不到,ios没办法安装老版本的米家。其它的几个参 ...
ios可以安装旧版app的,同样是抓包,教程一搜就有了,我在用的版本是5.1.1,这个版本支持新设备而且没有加密
27hh
教程狂人论坛风云人物
 楼主| 发表于 2021-1-24 19:45:27 | 显示全部楼层
MX10085 发表于 2021-1-24 15:04
空调伴侣,净水器,扫地机这些怎么配置?
空调伴侣已经有现成的插件了,净水器不知道你需要什么功能,可以通过传感器和开关接入;扫地机后期会支持,告诉我你的扫地机型号
GMT+8, 2025-9-14 03:07 , Processed in 1.303950 second(s), 12 queries , MemCached On.
