查看: 114960|回复: 91
[经验分享] 米家门锁通过多模接入ha后利用自动化分离门和锁的状态下
 火.. [复制链接]
81
3万
发表于 2021-1-5 14:22:03 | 显示全部楼层 |阅读模式
2023年3月4日更新:
经过论坛帖子的学习,今天突然想到仅用模板就可以解决这个门锁状态的问题。新版的template有trigger可以用了,如果再有环境条件就可以更简化了。
现在的gateway3集成的小米蓝牙门锁的实体已经有 binary_sensor.xxxxxxx_contact 门的开关状态了,大部分自动化也够用了。
再增加“门内开锁,指纹开锁”等信息就可以了。
sensor.e50b9a2d2a9f_action 换成自己门锁的 action实体ID即可。重启ha不影响各模板实体状态。
代码也可以放在packages目录下的一个yaml文件中:
template:
  - trigger:
      - platform: state
        entity_id:
          - sensor.e50b9a2d2a9f_action
        attribute: message
        to:
          - 'Unlock outside the door'
          - 'Lock'
          - 'Turn on anti-lock'
          - 'Turn off anti-lock'
          - 'Unlock inside the door'
          - 'Lock inside the door'
          - 'Turn on child lock'
          - 'Turn off child lock'
          - 'Knock on the door'
          - 'Breaking the door'
          - 'Door is stuck'
        not_from:
          - unknown
          - unavailable
      unique_id: xiaomi_smartlock_state
      state: |
        {% if is_state_attr('sensor.e50b9a2d2a9f_action','action_id',0) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"lock") %}
          门外开锁
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',1) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"lock") %}
          上提把手上锁
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',2) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"lock") %}
          反锁
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',3) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"lock") %}
          解除反锁
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',4) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"lock") %}
          门内开锁
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',5) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"lock") %}
          门内上锁
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',6) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"lock") %}
          开启童锁
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',7) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"lock") %}
          关闭童锁
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',0) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"door") %}
          开门
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',1) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"door") %}
          关门
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',2) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"door") %}
          超时未关
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',3) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"door") %}
          敲门
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',4) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"door") %}
          门被破坏
        {% elif is_state_attr('sensor.e50b9a2d2a9f_action','action_id',5) and is_state_attr('sensor.e50b9a2d2a9f_action','action',"door") %}
          门卡住了
        {% else %}
          action_id:{{ state_attr('sensor.e50b9a2d2a9f_action','action_id') }}
        {% endif %}
  - trigger:
      - platform: state
        entity_id:
        attribute: method_id
        to:
          - 0
          - 1
          - 2
          - 3
          - 4
          - 5
          - 6
          - 7
          - 8
          - 10
          - 11
        not_from:
          - unknown
          - unavailable
      - platform: state
        entity_id:
        to: lock
        not_from:
          - unknown
          - unavailable
      unique_id: xiaomi_smartlock_open_method
      state: |
        {% if state_attr('sensor.e50b9a2d2a9f_action','method_id') == 0 %}
          蓝牙
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 1 %}
          密码
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 2 %}
          指纹
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 3 %}
          钥匙
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 4 %}
          转盘
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 5 %}
          NFC
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 6 %}
          一次性密码
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 7 %}
          双重验证
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 8 %}
          强制
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 10 %}
          人工
        {% elif state_attr('sensor.e50b9a2d2a9f_action','method_id') == 11 %}
          自动
        {% else %}
          method_id:{{ state_attr('sensor.e50b9a2d2a9f_action','method_id') }}
        {% endif %}
  - trigger:
      - platform: state
        entity_id:
        attribute: key_id
        to:
          - 0
          - 1
          - 2
          - 3
          - 4
          - 5
          - 6
          - 7
          - 8
          - 9
          - 10
          - 11
          - 12
          - 13
          - 14
          - 15
          - 16
          - 17
          - 18
          - 19
          - 20
          - 'ffffffff'
          - 'DEADBEEF'
          - 0xc0de0000
          - 0xc0de0001
          - 0xc0de0002
          - 0xc0de0003
          - 0xc0de0004
          - 0xc0de0005
          - 0xc0de0006
          - 0xc0de0007
          - 0xc0de0008
          - 0xc0de0009
          - 0xc0de000a
          - 0xc0de000b
          - 0xc0de000c
          - 0xc0de000d
          - 0xc0de000e
          - 0xc0de000f
          - 0xc0de0010
          - 0xc0de1000
          - 0xc0de1001
          - 0xc0de1002
          - 0xc0de1003
          - 0xc0de1004
      unique_id: xiaomi_smartlock_open_key
      state: |
        {% if state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0 %}
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 2 %}
          我的指纹
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 6 %}
          我的右手指纹
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 1 %}
          我的密码
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 3 %}
          老爸的指纹
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 5 %}
          老婆的指纹
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 7 %}
          老婆的右手指纹
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 'ffffffff' %}
          未知操作者
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 'DEADBEEF' %}
          无效操作者
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0000 %}
          错误的密码解锁次数过多
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0001 %}
          错误指纹解锁次数过多
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0002 %}
          操作超时(密码输入超时)
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0003 %}
          开锁
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0004 %}
          重置按钮被按下
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0005 %}
          钥匙弄错次数过多
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0006 %}
          钥匙孔内有异物
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0007 %}
          钥匙未取出
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0008 %}
          错误的NFC频繁解锁
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0009 %}
          超时未按要求锁定
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de000a %}
          多种方式频繁解锁失败
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de000b %}
          人脸解锁失败次数过多
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de000c %}
          静脉解锁失败次数过多
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de000d %}
          劫持报警
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de000e %}
          布防后在门内解锁
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de000f %}
          掌纹解锁失败次数过多
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de0010 %}
          保险被移除
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de1000 %}
          电池电量低于 10%
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de1001 %}
          电池电量低于 5%
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de1002 %}
          指纹传感器异常
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de1003 %}
          附件电池电量低
        {% elif state_attr('sensor.e50b9a2d2a9f_action','key_id') == 0xc0de1004 %}
          机械故障
        {% else %}
          {{ state_attr('sensor.e50b9a2d2a9f_action','key_id') }}
        {% endif %}
  - trigger:
      - platform: state
        entity_id: sensor.e50b9a2d2a9f_action
      unique_id: xiaomi_smartlock_do_time
      state: >
        {{ as_local(states.sensor.e50b9a2d2a9f_action.last_changed).strftime('%Y-%m-%d %H:%M:%S') }}
大大简化之前的方法,看起来效果几乎一样。
另非常感谢 louis_lee 大佬 在 76楼的分享。
-------上面代码更新后,以下部分已弃用-(非参考思路的话可以不看了)----
-----------------2021-10-10 更新----------------------
XiaomiGateway3 v1.5.1-rc.1已经修复action的bug。
-----------------2021-9-30 更新----------------------
多模网关插件 XiaomiGateway3 1.5.0被作者标记了一处Bug,https://github.com/AlexxIT/XiaomiGateway3/issues/469。
暂时可将代码中的锁动作显示中文的触发条件的到状态值由 lock 改为 key_id。
或者手动修改插件1.5.0中的代码,sensor.py 中324行:
将 elif k in ('key_id', 'lock_control', 'lock_state'):
改为 elif k in ('lock_control', 'lock_state'):
估计下一版作者应该会修复吧,修复后按原来的就可以了。
-----------------以下部分由 dscao 于 2021-1-31 01:48 编辑-----------------------
看到有坛友也提出这个思路或问题,我把我现在用的方法也分享一下,不过也还有一些不足的地方,希望也能找到更好的方案。
多模网关中门锁中门状态和锁状态共用一个 sensor.XXXXXX_action  ,导致用新建模板sensor,会出现有时一个为空。
所以利用自动化判断action来设定门的状态和锁的状态及其它相关的状态。
首先要安装 python_script,在ha的config目录中加入 python_scripts/set_state.py
内容为:
if 'entity_id' not in data:
    logger.warning("===== entity_id is required if you want to set something.")
else:
    data = data.copy()
    inputEntity = data.pop('entity_id')
    inputStateObject = hass.states.get(inputEntity)
    if inputStateObject:
        inputState = inputStateObject.state
        inputAttributesObject = inputStateObject.attributes.copy()
    else:
        inputState = 'unknown'
        inputAttributesObject = {}
    if 'state' in data:
        inputState = data.pop('state')
    logger.debug("===== new attrs: {}".format(data))
    inputAttributesObject.update(data)
    hass.states.set(inputEntity, inputState, inputAttributesObject)
在 configuration.yaml 加入一句:
python_script:
启用这个。
2021年1月31日更新,门状态通过模板,因为只有开和关两种状态,可以不需要自动化来更新了,但锁状态还是要通过自动化来更新。:
设置几个模板Sensor,可以在packages目录下的yaml文件中:
binary_sensor:
  - platform: template
    sensors:
      smartlock_door:
        friendly_name: 门状态
        value_template: >-
          {% if (is_state_attr('sensor.e50b9a2dxxxx_action','action_id',0) and is_state_attr('sensor.e50b9a2dxxxx_action','action',"door")) or (is_state_attr('sensor.e50b9a2dxxxx_action','action_id',2) and is_state_attr('sensor.e50b9a2dxxxx_action','action',"door"))%}
            on
          {% else %}
            off
          {% endif %}
        icon_template: >-
            mdi:door-open
          {% else %}
            mdi:door-closed-lock
          {% endif %}
    sensors:
      smartlock_state:
        friendly_name: 门锁状态
        value_template: 未知
      smartlock_method:
        friendly_name: 开门方式
        value_template: 未知
      smartlock_user:
        friendly_name: 操作者
        value_template: 未知
      smartlock_changetime:
        friendly_name: 操作时间
        value_template: >-
          {% if as_timestamp(states.sensor.e50b9a2dxxxx_action.last_updated) > as_timestamp(states.sensor.xi_tong_qi_dong_shi_jian.state) %}
            {{ as_local(states.sensor.e50b9a2dxxxx_action.last_changed).strftime('%Y-%m-%d %H:%M:%S') }}
          {% else %}
            无
          {% endif %}
homeassistant:
  customize:
    sensor.smartlock_state:
      icon: mdi:lock-smart
    sensor.smartlock_method:
      icon: mdi:lock-question
    sensor.smartlock_user:
      icon: mdi:human-handsdown
    sensor.smartlock_changetime:
      icon: mdi:lock-clock
一个自动化改变锁的状态,门的状态上面通过模板可自动更新:
alias: 锁动作显示中文
description: ''
trigger:
  - platform: state
    entity_id: sensor.e50b9a2dxxxx_action
    to: lock
condition: []
action:
  - service: python_script.set_state
    data:
      entity_id: sensor.smartlock_method
      state: |
        {% if trigger.to_state.attributes['method_id'] == 0 %}
          蓝牙
        {% elif trigger.to_state.attributes['method_id'] == 1 %}
          密码
        {% elif trigger.to_state.attributes['method_id'] == 2 %}
          指纹
        {% elif trigger.to_state.attributes['method_id'] == 3 %}
          钥匙
        {% elif trigger.to_state.attributes['method_id'] == 4 %}
          转盘
        {% elif trigger.to_state.attributes['method_id'] == 5 %}
          NFC
        {% elif trigger.to_state.attributes['method_id'] == 6 %}
          一次性密码
        {% elif trigger.to_state.attributes['method_id'] == 7 %}
          双重验证
        {% elif trigger.to_state.attributes['method_id'] == 10 %}
          人工
        {% elif trigger.to_state.attributes['method_id'] == 11 %}
          自动
        {% else %}
          method_id:{{ trigger.to_state.attributes['method_id'] }}
        {% endif %}
    data:
      entity_id: sensor.smartlock_state
      state: |
        {% if is_state_attr('sensor.e50b9a2dxxxx_action','action_id',0) %}
          门外开锁
        {% elif is_state_attr('sensor.e50b9a2dxxxxx_action','action_id',1) %}
          上提把手上锁
        {% elif is_state_attr('sensor.e50b9a2dxxxx_action','action_id',2) %}
          反锁
        {% elif is_state_attr('sensor.e50b9a2dxxxx_action','action_id',3) %}
          解除锁
        {% elif is_state_attr('sensor.e50b9a2dxxxx_action','action_id',4) %}
          门内开锁
        {% elif is_state_attr('sensor.e50b9a2dxxxx_action','action_id',5) %}
          门内上锁
        {% elif is_state_attr('sensor.e50b9a2dxxxx_action','action_id',6) %}
          开启童锁
        {% elif is_state_attr('sensor.e50b9a2dxxxx_action','action_id',7) %}
          关闭童锁
        {% else %}
          action_id:{{ state_attr('sensor.e50b9a2dxxxx_action','action_id') }}
        {% endif %}
    data:
      entity_id: sensor.smartlock_user
      state: |
        {% if trigger.to_state.attributes['key_id'] == 0 %}
        {% elif trigger.to_state.attributes['key_id'] == 2 %}
          我的指纹
        {% elif trigger.to_state.attributes['key_id'] == 6 %}
          我的右手指纹
        {% elif trigger.to_state.attributes['key_id'] == 1 %}
          我的密码
        {% elif trigger.to_state.attributes['key_id'] == 3 %}
          老爸的指纹
        {% elif trigger.to_state.attributes['key_id'] == 5 %}
          老婆的指纹
        {% elif trigger.to_state.attributes['key_id'] == 7 %}
          老婆的右手指纹
        {% elif trigger.to_state.attributes['key_id'] == 'ffffffff' %}
          未知操作者
        {% elif trigger.to_state.attributes['key_id'] == 'DEADBEEF' %}
          无效操作者
        {% else %}
          {{ trigger.to_state.attributes['key_id'] }}
        {% endif %}
mode: single
效果:
参与人数 6金钱 +54 收起 理由
juno277 + 2
jajanuj + 1 感谢楼主分享!
louis_lee + 16 来抄作业啦!
adr + 5 膜拜大神!
+ 20 感谢楼主分享!
0703005 + 10 谢谢楼主,这样下来省去了一个8266.
发表于 2021-1-5 15:08:23 | 显示全部楼层
谢谢分享,从另外一个帖子过来啦,我想请问一下是怎么实现区分老爸指纹和其他用户指纹开门的,我在那个帖子的意思是好像这些用户信息现有的插件没有推送到到HA
我回复的太快了,看到你更新了最后那段代码,所以请问一下key id是在哪里查看呢?
发表于 2021-1-5 15:40:45 | 显示全部楼层
感谢分享!
新版ha,自动化这个缩进貌似不能直接粘贴到yaml使用啊。
automation:
  - alias: 门锁动作显示中文
    trigger:
我的这个缩进
3万
 楼主| 发表于 2021-1-5 16:07:07 | 显示全部楼层
AnyLine 发表于 2021-1-5 15:40
感谢分享!
我就是从自动化,右上角,以yaml编辑,复制出来的,应该可以直接复制进去,可能要修改一下门锁的实体ID才能保存。原来是用ui写的。
3万
 楼主| 发表于 2021-1-5 16:09:15 | 显示全部楼层
Sourdough 发表于 2021-1-5 15:08
谢谢分享,从另外一个帖子过来啦,我想请问一下是怎么实现区分老爸指纹和其他用户指纹开门的,我在那个帖子 ...
用指纹开锁试一下,在门锁Action的属性中就有。实际上小米锁添加指纹或密码时的顺序,但不成功也会占一个序号。
发表于 2021-1-5 16:14:19 | 显示全部楼层
dscao 发表于 2021-1-5 16:07
我就是从自动化,右上角,以yaml编辑,复制出来的,应该可以直接复制进去,可能要修改一下门锁的实体ID才 ...
好像不对啊,你是哪个版本的ha?
我的打开automations.yaml文件的话里面是
- id: '1609752430998'
  alias: 新建自动化
  description: ''
开头的自动化或者
- alias: 门锁动作显示中文2
  description: ''
  trigger:
如果是别的yaml文件,手动写进自动化应该
automation:
  - alias: 门动作显示中文1
    description: ''
    trigger:
开头加上automation:
发表于 2021-1-5 16:19:34 | 显示全部楼层
效果图里的门锁日志那个是哪个实体的历史记录呢?
3万
 楼主| 发表于 2021-1-5 16:41:09 | 显示全部楼层
那是新版ha中 编辑仪表盘 UI中的自带的日志卡片
发表于 2021-1-5 16:48:46 | 显示全部楼层
用 action_id 和 method_id 判断比这个靠谱些, 翻译随时会变的
发表于 2021-1-6 03:26:41 | 显示全部楼层
“首先要安装python_script,在哈的配置目录中加入python_scripts / set_state.py”  大佬你的这一句我不理解,我是通过PVE安装的hassos  怎么添加呢?  还望能给小白讲解下。 谢谢
GMT+8, 2025-9-15 03:11 , Processed in 0.650150 second(s), 11 queries , MemCached On.
