楼主: goodheartman
[技术探讨] 米家门锁如何接入Homekit
 楼主| 发表于 2021-1-6 09:23:19 | 显示全部楼层
昨天重新想了一下再加上国外HA的资料, 竟然被我搞出来, 所以就来自问自答
[思路]
Binary sensor 无法处理 event, 所以先建立一个 input boolean 转换资讯
之后 event 透过 automation 进行辨识
Event -> Automation -> input boolean -> binary sensor -> Homekit
以下是我自己编出来的, 仅截取门开阖状态以及上锁状态 Event 给 Homekit 生成传感器
input_boolean:
  mi_door:
    icon: mdi:door
  mi_doorlock:
    name: Xiaomi Door Lock
    icon: mdi:lock
binary_sensor:
  - platform: template
    sensors:
      xiaomi_door:
        friendly_name: "Xiaomi Door"
        device_class: "door"
        value_template: "{{ is_state('input_boolean.mi_door', 'on') }}"
      xiaomi_doorlock:
        friendly_name: "Xiaomi Door Lock"
        device_class: "lock"
        value_template: "{{ is_state('input_boolean.mi_doorlock', 'on') }}"
automation:
  - alias: door open
    trigger:
      platform: state
      entity_id: sensor.门锁编号_action
      to: door
    condition:
      condition: template
      value_template: "{{ trigger.to_state.attributes['action_id'] == 0 }}"
    action:
      service: input_boolean.turn_on
      data:
        entity_id: input_boolean.mi_door
  - alias: door closed
    trigger:
      platform: state
      to: door
    condition:
      condition: template
      value_template: "{{ trigger.to_state.attributes['action_id'] == 1 }}"
    action:
      service: input_boolean.turn_off
      data:
  - alias: door locked
    trigger:
      platform: state
      to: lock
    condition:
      condition: or
      conditions:
        -  condition: template
           value_template: "{{ trigger.to_state.attributes['action_id'] == 5 }}"
    action:
      data:
        entity_id: input_boolean.mi_doorlock
  - alias: door unlock
    trigger:
      platform: state
      to: lock
    condition:
      condition: or
      conditions:
           value_template: "{{ trigger.to_state.attributes['action_id'] == 4 }}"
    action:
      data:
发表于 2021-3-9 21:25:05 | 显示全部楼层
[思路]
请问这个是要用哪个接入?
 楼主| 发表于 2021-3-11 17:01:23 | 显示全部楼层
gosrak 发表于 2021-3-9 21:25
请问这个是要用哪个接入?
先把多模网关接上 HA
确认实体有被HA接入之后就是编写configuration.yaml
接着就是上面的程式码接入Homekit
发表于 2021-3-11 18:41:34 | 显示全部楼层
goodheartman 发表于 2021-3-11 17:01
先把多模网关接上 HA
接着就是上面的程式码接入Hom ...
这个全部复制到configuration.yaml吗
 楼主| 发表于 2021-3-11 20:19:12 | 显示全部楼层
应该是可以的, 记得程式码门锁编号的部分替换成你门锁实体编号
发表于 2021-11-16 10:24:42 | 显示全部楼层
dscao 发表于 2021-1-5 01:18
思路有点像,多模网关接入的,没有之前mqttl的分开状态了,我是用自动化修改模板sensor或binary sensorr的 ...
您好,13356775995,我想在家里搞点智能控制东西,能加您微信请教吗?谢谢。
发表于 2021-12-10 14:26:10 | 显示全部楼层
这个很有用!
GMT+8, 2025-9-17 03:08 , Processed in 0.683775 second(s), 13 queries , MemCached On.
