楼主: involute
[技术探讨] 关于V3版美的空调控制协议
我就是六神
活跃会员教程狂人灌水之王
发表于 2021-1-11 20:46:37 | 显示全部楼层
Found a unsupported device - type: '0xe2' - version: V2 - ip: 192.168.31.217 - port: 644
4 - id: 17592**71***767 - sn: 0000E221100030W9S1*******1160000 - ssid: midea_e2_1116
发表于 2021-1-25 21:19:43 | 显示全部楼层
Found a supported 'ac' (44204) at 10.10.10.58:6444 - id: 1616******4120 - sn: 00000031**********507B03640000 - ssid: midea_ac_0364 - mac: a0*******615 - protocol: 3
发表于 2021-1-25 21:21:27 | 显示全部楼层
然后登陆失败了
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 199, in _async_setup_platform
    await asyncio.shield(task)
  File "/config/custom_components/midea_ac/climate.py", line 73, in async_setup_platform
    device.authenticate(device_8370_only_ac_mac, device_8370_only_wifi_ssid, device_8370_only_wifi_pw)
  File "/usr/local/lib/python3.8/site-packages/msmart/device.py", line 43, in authenticate
    self._authenticate()
  File "/usr/local/lib/python3.8/site-packages/msmart/device.py", line 46, in _authenticate
    self._lan_service.authenticate(self._mac, self._wifi_ssid, self._wifi_pw)
  File "/usr/local/lib/python3.8/site-packages/msmart/lan.py", line 68, in authenticate
  File "/usr/local/lib/python3.8/site-packages/msmart/lan.py", line 80, in _authenticate
    raise error
  File "/usr/local/lib/python3.8/site-packages/msmart/lan.py", line 76, in _authenticate
    tcp_key = self.security.tcp_key(response, self._key)
  File "/usr/local/lib/python3.8/site-packages/msmart/security.py", line 90, in tcp_key
    raise Exception('authentication failed')
Exception: authentication failed
发表于 2021-2-28 20:42:23 | 显示全部楼层
看msmart的结果是支持的但是homeassistant最后还是验证失败
msmart:
hass:
有没有人成功了,给点经验呀。
发表于 2021-6-11 14:21:28 | 显示全部楼层
v3不支持
发表于 2022-1-28 14:00:36 | 显示全部楼层
有一个v3的空调支持了,控制还有点问题,用Wireshark抓包,发现全是加密的,请问如何解密?
发表于 2023-6-1 13:24:13 | 显示全部楼层
支持乐享三吗
发表于 2023-8-2 17:58:42 | 显示全部楼层
我有支持的
发表于 2023-11-11 14:44:17 | 显示全部楼层
开源吗?还是付费的
发表于 2023-12-27 12:01:24 | 显示全部楼层
yuanshi 发表于 2023-11-11 14:44
开源吗?还是付费的
media_lan已更新,免费的
GMT+8, 2025-9-18 04:01 , Processed in 0.722530 second(s), 11 queries , MemCached On.
