楼主: mac_zhou
[插件集成] 小米空调伴侣插件-请大家使用syssi大神的版本
 火.. [复制链接]
发表于 2017-11-17 21:04:07 | 显示全部楼层
2017-11-17 21:03:10 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform mi_acpartner
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/helpers/entity_component.py", line 170, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
    return fut.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/home/pi/.homeassistant/custom_components/climate/mi_acpartner.py", line 134, in setup_platform
    token, sensor_entity_id, sync, customize),
  File "/home/pi/.homeassistant/custom_components/climate/mi_acpartner.py", line 207, in __init__
    self._state = self.climate_get_state()
  File "/home/pi/.homeassistant/custom_components/climate/mi_acpartner.py", line 473, in climate_get_state
    getstate = self.climate.send("get_model_and_state", [])
  File "/home/pi/.homeassistant/custom_components/climate/mi_acpartner.py", line 289, in climate
    self._climate = miio.device(self.host, self.token)
TypeError: 'module' object is not callable
报 错 楼主
发表于 2017-11-17 23:23:45 | 显示全部楼层
yqowen 发表于 2017-10-27 14:57
多谢分享,在HA里已经可以进行简单的空调操作了。
请问怎么获取target_sensor呢?在home assistant的states里看不到sensor.temperature_xxxxxxxxx的号啊?感谢
发表于 2017-11-18 00:12:39 | 显示全部楼层
olccamy 发表于 2017-11-17 21:04
[code]2017-11-17 21:03:10 ERROR (MainThread) [homeassistant.components.clima ...
查了下,应该是miio.Device(self.host,self.token)
发表于 2017-11-18 00:37:55 | 显示全部楼层
ozjso 发表于 2017-11-17 23:23
请问怎么获取target_sensor呢?在home assistant的states里看不到sensor.temperature_xxxxxxxxx的号啊? ...
我是设置了连在伴侣上的温度传感器 这个在米家app里空调伴侣设备列表里可以查看的
发表于 2017-11-19 14:17:33 | 显示全部楼层
yqowen 发表于 2017-11-18 00:37
我是设置了连在伴侣上的温度传感器 这个在米家app里空调伴侣设备列表里可以查看的 ...
我的是IOS系统,看不到温度传感器,你是安卓的吗?我看到的是mofrl:lumi.acpaterner.v1。刚才拿安卓的系统看了一下,还是一样,只有设备的中文名:空调伴侣,但就是看不到详细的设备号。能否细说怎么看到温度传感器的设备号。谢啦
 楼主| 发表于 2017-11-20 16:55:05 | 显示全部楼层
版本问题,请更新最新版本,刚还有人pull了代码
发表于 2017-11-20 22:05:34 | 显示全部楼层
更新的好即时,我刚更新到0.68,发现有点问题就上来看看,发现已更新了,必须要顶一下
发表于 2017-11-20 22:17:56 | 显示全部楼层
新版本已解决  但是接入HOMEKIT时  打开空调 和  关闭空调指令 无法使用  直接按也不起作用  只能直接调整温度来开启  也只能在模式里面选 择关闭空调
教程狂人论坛风云人物
发表于 2017-11-20 22:56:58 | 显示全部楼层
hi 大神 你好,我已经通过你的插件间接让小爱控制ha,https://bbs.hassbian.com/thread-1777-1-1.html
不过遇到了难题,就是手机app控制空调伴侣,然后在ha的状态反馈存在延时,不知道是否能解决这个延时的问题呢?
尝试过萝卜,我想你一定会忘记青瓜
 楼主| 发表于 2017-11-21 12:12:52 | 显示全部楼层
不过 ...
代码中默认是15秒获取状态,你可以改小一些试试
配置参数是 sync
具体配置请参考github
GMT+8, 2025-9-19 02:34 , Processed in 0.651602 second(s), 11 queries , MemCached On.
