楼主: mac_zhou
[插件集成] 小米空调伴侣插件-请大家使用syssi大神的版本
 火.. [复制链接]
发表于 2017-9-12 23:33:20 | 显示全部楼层
你好楼主,我已经将下载的py文件放入相应文件夹,但是依旧报错,能帮我看一下吗:谢谢了
2017-09-12 15:48:38 WARNING (MainThread) [homeassistant.setup] Setup of climate is taking over 10 seconds.2017-09-12 15:48:39 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform mi_acpartnerTraceback (most recent call last):  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)  File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for    return fut.result()  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result    raise self._exception  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run    result = self.fn(*self.args, **self.kwargs)  File "/home/homeassistant/.homeassistant/custom_components/climate/mi_acpartner.py", line 130, in setup_platform    _LOGGER.info(customize['fan'].keys())TypeError: 'NoneType' object is not subscriptable
amos
发表于 2017-9-13 01:13:45 | 显示全部楼层
出错了,楼主能不能帮忙看看。发不了图
2017-09-12 16:49:48 ERROR (MainThread) [homeassistant.setup] Not initializing climate.mi_acpartner because could not install dependency python-miio==0.0.11
2017-09-12 16:49:48 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform climate.mi_acpartner: Could not install all requirements.
发表于 2017-9-13 08:35:47 | 显示全部楼层
amos 发表于 2017-9-13 01:13
出错了,楼主能不能帮忙看看。发不了图
2017-09-12 16:49:48 ERROR (MainThread) [homeassistant.setup] No ...
楼上,你sudo pip3 install pip3 python-miio
再来看看会不会出现跟我一样的问题
 楼主| 发表于 2017-9-13 09:43:07 | 显示全部楼层
2017-09-12 15:48: ...
已经更新,重新试试
 楼主| 发表于 2017-9-13 09:48:16 | 显示全部楼层
出错了,楼主能不能帮忙看看。发不了图
sudo pip3 install python-miio==0.0.11
amos
发表于 2017-9-13 13:00:45 | 显示全部楼层
再来看看会不会出现跟我一样的问题
谢谢,已经弄好了
amos
发表于 2017-9-13 13:03:24 | 显示全部楼层
感谢大神指点!已经弄好。
现在homekit里存在两个重复的空调,siri语音控制的话会执行两次,滴滴响两声。
我是不是把之前homebridge里安装的mi-acpartner这个插件卸载掉就可以了?
amos
发表于 2017-9-13 13:06:05 | 显示全部楼层
homebridge版本的mi-acpartner,不能获取温度反馈,总是30度,要想有温度反馈必须得把温湿度计加入到小米空调伴侣的网关里。
现在楼主这个homeassistant更完善了,温湿度计不需要绑定到空调伴侣下面也可以
 楼主| 发表于 2017-9-13 14:28:41 | 显示全部楼层
amos 发表于 2017-9-13 13:03
感谢大神指点!已经弄好。
现在homekit里存在两个重复的空调,siri语音控制的话会执行两次,滴滴响两声。 ...
你改不同的名字不就共存了呀
共存着方便对比嘛 233
 楼主| 发表于 2017-9-13 14:30:09 | 显示全部楼层
amos 发表于 2017-9-13 13:06
homebridge版本的mi-acpartner,不能获取温度反馈,总是30度,要想有温度反馈必须得把温湿度计加入到小米空 ...
好像homebridge的限制,所以没办法
hass是啥限制,所以没关系
GMT+8, 2025-9-15 03:34 , Processed in 0.623559 second(s), 6 queries , MemCached On.
