查看: 10090|回复: 11
[已解决] esxi 安装hassos后 安装node-red 打开页面提示502
发表于 2020-11-10 18:12:32 | 显示全部楼层 |阅读模式
系统已经安装了5-6次了.都无法搞定
安装vscode 打开页面一直是白的
安装node-red 页面提示502
我的访问端口是10.0.0.3:8123
请各位大神指点
 楼主| 发表于 2020-11-10 18:17:40 | 显示全部楼层
vscode 日志正常
但是点击后open web ui 后页面是白的
fiddler 跟踪:
这个请求可以正常返回vscode信息
/api/hassio/addons/a0d7b954_vscode/info
但是后续请求一直无返回:
/api/hassio_ingress/cpbu7wEV_6_Ji8qDTHLqlu1bii731F6F6vxx3raqFJA/
启动日志:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: Visual Studio Code
Fully featured VSCode experience, to edit your HA config in the browser, including auto-completion!
Add-on version: 2.8.2
You are running the latest version of this add-on.
System: HassOS 4.15  (amd64 / qemux86-64)
Home Assistant Core: 0.117.5
Home Assistant Supervisor: 2020.11.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] code-server.sh: executing...
[cont-init.d] code-server.sh: exited 0.
[cont-init.d] mosquitto.sh: executing...
[cont-init.d] mosquitto.sh: exited 0.
[cont-init.d] mysql.sh: executing...
[cont-init.d] mysql.sh: exited 0.
[cont-init.d] user.sh: executing...
[cont-init.d] user.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[18:09:01] INFO: Starting the code server...
[2020-11-10T10:09:02.109Z] info  Wrote default config file to ~/.config/code-server/config.yaml
[2020-11-10T10:09:02.470Z] info  Using user-data-dir /data/vscode
[2020-11-10T10:09:02.477Z] info  code-server 3.6.0 a4a03c14922ccaec2a9ff8d1b7b2af8522a4214d
[2020-11-10T10:09:02.478Z] info  Using config file ~/.config/code-server/config.yaml
[2020-11-10T10:09:02.484Z] info  HTTP server listening on http://0.0.0.0:1337
[2020-11-10T10:09:02.484Z] info    - No authentication
[2020-11-10T10:09:02.484Z] info    - Not serving HTTPS
 楼主| 发表于 2020-11-10 18:35:25 | 显示全部楼层
node-red 日志
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.[s6-init] ensuring user provided files have correct perms...exited 0.[fix-attrs.d] applying ownership & permissions fixes...[fix-attrs.d] done.[cont-init.d] executing container initialization scripts...[cont-init.d] 00-banner.sh: executing... ----------------------------------------------------------- Add-on: Node-RED Flow-based programming for the Internet of Things----------------------------------------------------------- Add-on version: 7.2.8 You are running the latest version of this add-on. System: HassOS 4.15  (amd64 / qemux86-64) Home Assistant Core: 0.117.5 Home Assistant Supervisor: 2020.11.0----------------------------------------------------------- Please, share the above information when looking for help or support in, e.g., GitHub, forums or the Discord chat.-----------------------------------------------------------[cont-init.d] 00-banner.sh: exited 0.[cont-init.d] 01-log-level.sh: executing... [cont-init.d] 01-log-level.sh: exited 0.[cont-init.d] nginx.sh: executing... [cont-init.d] nginx.sh: exited 0.[cont-init.d] node-red.sh: executing... [18:33:54] INFO: Password is NOT in the Have I Been Pwned database! Nice![18:33:55] INFO: Password is NOT in the Have I Been Pwned database! Nice!patching file nodes/ui_base.htmlHunk #1 succeeded at 1178 (offset 647 lines).[cont-init.d] node-red.sh: exited 0.[cont-init.d] user.sh: executing... fetch http://dl-cdn.alpinelinux.org/al ... PKINDEX.tar.gzfetch http://dl-cdn.alpinelinux.org/al ... _64/APKINDEX.tar.gz
 楼主| 发表于 2020-11-10 18:36:40 | 显示全部楼层
20-11-10 10:08:37 INFO (MainThread) [supervisor.addons] Add-on 'a0d7b954_vscode' successfully installed
20-11-10 10:08:58 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-11-10 10:08:58 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for a0d7b954_vscode
20-11-10 10:09:01 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on hassioaddons/vscode-amd64 with version 2.8.2
20-11-10 10:09:01 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_vscode
20-11-10 10:09:27 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for a0d7b954_vscode
20-11-10 10:09:44 INFO (MainThread) [supervisor.addons] Creating Home Assistant add-on data folder /data/addons/data/a0d7b954_nodered
20-11-10 10:09:44 INFO (SyncWorker_5) [supervisor.docker.interface] Downloading docker image hassioaddons/node-red-amd64 with tag 7.2.8.
20-11-10 10:09:49 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image hassioaddons/node-red-amd64 with tag 7.2.8.
20-11-10 10:14:32 INFO (MainThread) [supervisor.addons] Add-on 'a0d7b954_nodered' successfully installed
[fix-attrs.d] done.
[cont-init.d] udev.sh: executing...
[18:28:46] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] done.
[18:28:46] INFO: Starting local supervisor watchdog...
20-11-10 18:28:48 INFO (MainThread) [__main__] Initializing Supervisor setup
20-11-10 18:28:48 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
20-11-10 18:28:48 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2020.11.0
20-11-10 18:28:48 INFO (MainThread) [__main__] Setting up Supervisor
20-11-10 18:28:48 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
20-11-10 18:28:48 INFO (MainThread) [supervisor.host.info] Updating local host information
20-11-10 18:28:48 INFO (MainThread) [supervisor.host.services] Updating service information
20-11-10 18:28:48 INFO (MainThread) [supervisor.host.network] Updating local network information
20-11-10 18:28:48 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
20-11-10 18:28:48 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
20-11-10 18:28:48 INFO (MainThread) [supervisor.host.services] Reloading local service hassos-apparmor.service
20-11-10 18:28:48 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-dns with version 2020.11.0
20-11-10 18:28:48 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
20-11-10 18:28:48 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_dns application
20-11-10 18:28:49 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS homeassistant/amd64-hassio-dns with version 2020.11.0 - 172.30.32.3
20-11-10 18:28:49 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
20-11-10 18:28:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-audio with version 17
20-11-10 18:28:49 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
20-11-10 18:28:49 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_audio application
20-11-10 18:28:49 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio homeassistant/amd64-hassio-audio with version 17 - 172.30.32.4
20-11-10 18:28:49 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-cli with version 2020.10.1
20-11-10 18:28:49 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
20-11-10 18:28:49 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning hassio_cli application
20-11-10 18:28:50 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI homeassistant/amd64-hassio-cli with version 2020.10.1 - 172.30.32.5
20-11-10 18:28:50 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-observer with version 2020.10.1
20-11-10 18:28:50 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to homeassistant/amd64-hassio-multicast with version 3
20-11-10 18:28:50 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
20-11-10 18:28:50 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning hassio_multicast application
20-11-10 18:28:50 INFO (SyncWorker_2) [supervisor.docker.multicast] Starting Multicast homeassistant/amd64-hassio-multicast with version 3 - Host
20-11-10 18:28:50 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
20-11-10 18:28:50 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 1 Home Assistant secrets
20-11-10 18:28:50 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to homeassistant/qemux86-64-homeassistant with version 0.117.5
20-11-10 18:28:51 INFO (MainThread) [supervisor.hassos] Detect HassOS 4.15 / BootSlot A
20-11-10 18:28:51 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
20-11-10 18:28:51 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
20-11-10 18:28:51 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 66 new - 0 remove
20-11-10 18:28:51 INFO (MainThread) [supervisor.addons] Found 2 installed add-ons
20-11-10 18:28:51 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to hassioaddons/vscode-amd64 with version 2.8.2
20-11-10 18:28:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to hassioaddons/node-red-amd64 with version 7.2.8
20-11-10 18:28:51 INFO (MainThread) [supervisor.snapshots] Found 0 snapshot files
20-11-10 18:28:51 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
20-11-10 18:28:51 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
20-11-10 18:28:51 INFO (MainThread) [__main__] Running Supervisor
20-11-10 18:28:51 INFO (MainThread) [supervisor.hassos] Rauc: A - marked slot kernel.0 as good
20-11-10 18:28:51 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
20-11-10 18:28:51 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
20-11-10 18:28:51 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 1 add-ons
20-11-10 18:28:51 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_a0d7b954_vscode application
20-11-10 18:28:51 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on hassioaddons/vscode-amd64 with version 2.8.2
20-11-10 18:28:52 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_vscode
20-11-10 18:28:56 INFO (SyncWorker_2) [supervisor.docker.interface] Starting homeassistant
20-11-10 18:28:56 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
20-11-10 18:29:06 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
20-11-10 18:29:06 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
20-11-10 18:29:06 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 1 add-ons
20-11-10 18:29:07 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on hassioaddons/node-red-amd64 with version 7.2.8
20-11-10 18:29:07 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_nodered
20-11-10 10:30:36 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-11-10 10:30:36 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-11-10 10:30:36 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-11-10 10:30:36 INFO (MainThread) [supervisor.host.info] Updating local host information
20-11-10 10:30:36 INFO (MainThread) [supervisor.host.services] Updating service information
20-11-10 10:30:36 INFO (MainThread) [supervisor.host.network] Updating local network information
20-11-10 10:33:50 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_a0d7b954_nodered application
20-11-10 10:33:50 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on hassioaddons/node-red-amd64 with version 7.2.8
20-11-10 10:33:50 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_nodered
20-11-10 10:33:51 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_nodered
20-11-10 10:34:10 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for a0d7b954_nodered
20-11-10 10:34:16 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63243 ssl:default [Connect call failed ('172.30.32.1', 63243)]
20-11-10 10:34:54 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63243 ssl:default [Connect call failed ('172.30.32.1', 63243)]
系统日志这个error不知道是怎么回事
 楼主| 发表于 2020-11-10 18:43:40 | 显示全部楼层
http://10.0.0.3:1880
这个地址浏览器无法正常打开
 楼主| 发表于 2020-11-10 19:16:56 | 显示全部楼层
我怀疑是ha 的dns  locals dns是外网ip的原因???
 楼主| 发表于 2020-11-10 19:21:22 | 显示全部楼层
实在搞不定了..请大伟大神帮帮忙
发表于 2020-11-10 19:59:05 | 显示全部楼层
在NODERED插件中设置用户名密码:homeassistant
 楼主| 发表于 2020-11-11 12:22:17 | 显示全部楼层
现在情况是浏览器输入 http://10.0.0.3:1880/ 可以打开nodered 但是在集成面板还是空白的
Waer
陈二狗
发表于 2020-12-16 20:47:30 | 显示全部楼层
兄弟 你不是一个人  我也遇到了
二狗如何解决玄学bug:
1:重烧一次程序      2:插紧电线      3:吹一下灰尘
4:玩一会手机         5:放弃
GMT+8, 2025-9-7 05:03 , Processed in 0.285756 second(s), 12 queries , MemCached On.
