查看: 141789|回复: 113
[快速入门] 新手必备技能 【package】【检测配置】
教程狂人论坛风云人物突出贡献
发表于 2017-9-9 10:48:24 | 显示全部楼层 |阅读模式
package详细内容,见官方文档
https://home-assistant.io/docs/configuration/packages/
package使用,有种方法。这里推荐用下面这种。其他指定文件的方法,【见官方文档】
第一步:在configuration.yaml增加packages: !include_dir_named packages【注意缩进】
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 11.1111
  longitude: 111.11
第二步:在.homeassisatant文件夹【群晖docker、Hassio都是config文件夹】下新建packages文件夹
第三步:在packeages文件夹下新建yaml
这些yaml文件都是相互独立的配置文件【互不影响】
因此,建议一个yaml 写一个单独的功能模块,出问题了直接将yaml文件移除,这个功能也就移除了。
下面是device.yaml 作为范例
#设备在线
  - platform: template
    sensors:
      mate7:
        friendly_name: '华为Mate7'
        value_template: "{{ 'Online' if is_state('device_tracker.dnawdnbp_lidicnphone', 'home') else 'Offline' }}"
      mibox:
        friendly_name: '小米盒子'
        value_template: "{{ 'Online' if is_state('device_tracker.1048b196afde', 'home') else 'Offline' }}"
      notebook:
        friendly_name: '渣渣笔记本'
        value_template: "{{ 'Online' if is_state('device_tracker.desktopk870tpr', 'home') else 'Offline' }}"
#测速
  - platform: speedtest
    minute: 30
    hour:
      - 0
      - 6
      - 12
      - 18
    monitored_conditions:
      - ping
      - download
      - upload
#树莓派状态
  - platform: command_line
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    unit_of_measurement: "°C"
    value_template: '{{ value | multiply(0.001) | round(2) }}'
  - platform: systemmonitor
    resources:
    - type: memory_use_percent
    - type: processor_use
    - type: last_boot
    - type: memory_free
    - type: last_boot
    - type: since_last_boot
    - type: disk_use_percent
      arg: /
  ## Last boot Template
    sensors:
      since_last_boot_templated:
        value_template: >-
          {% if states.sensor.since_last_boot.state.count("day") > 0 %}
          {{states.sensor.since_last_boot.state.split(",") [0] +
          states.sensor.since_last_boot.state.split(",") [1].split(":") [0] +
          " hours, " +
          states.sensor.since_last_boot.state.split(",") [1].split(":") [1] +
          " minutes" }}
          {% else %}
          {{ "0 days, " +
          states.sensor.since_last_boot.state.split(",") [0].split(":") [0] +
          " hours, " +
          states.sensor.since_last_boot.state.split(",") [0].split(":") [1] +
          " minutes" }}
          {% endif %}
group:
  device:
    view: no
    entities:
    - sensor.mate7
    - sensor.mibox
    - sensor.notebook
    - sensor.speedtest_download
    - sensor.speedtest_upload
    - sensor.speedtest_ping
  raspberryPi:
    view: false
    entities:
    - sensor.cpu
    - sensor.cpu_use
    - sensor.ram_use
    - sensor.ram_free
    - sensor.disk_use_
    - sensor.last_boot
    - sensor.since_last_boot_templated
  Pcview:
    view: false
    entities:
    - sensor.glances_cpu_load
    - sensor.glances_disk_free
    - sensor.glances_disk_use
    - sensor.glances_disk_use_2
    - sensor.glances_ram_free
    - sensor.glances_ram_use
    - sensor.glances_ram_use_2
    - sensor.glances_running
    - sensor.glances_sleeping
    - sensor.glances_swap_free
    - sensor.glances_swap_use
    - sensor.glances_swap_use_2
    - sensor.glances_thread
    - sensor.glances_total
  time:
    view: false
    entities:
    - sensor.date
    - sensor.time
    - sensor.time_utc
    - sensor.sunrise_time
    - sensor.sunset_time
    - sensor.wedding_countdown
automation:
#电脑电源选项
  - alias: z800_restart
    trigger:
      platform: state
      entity_id: input_select.pcoptions
      to: "Restart"
    action:
      - service: shell_command.restart_z800
  - alias: z800_shutdown
    trigger:
      platform: state
      to: "Shutdown"
    action:
      - service: shell_command.shutdown_z800
  - alias: z800_sleep
    trigger:
      platform: state
      to: "Sleep"
    action:
      - service: shell_command.sleep_z800
  - alias: z800_hibernate
    trigger:
      platform: state
      to: "Hibernate"
    action:
      - service: shell_command.hibernate_z800
homeassistant:
  customize:
    automation.z800_restart:
      friendly_name: 渣渣笔记本重启
      homebridge_hidden: true
      icon: mdi:laptop-windows
    automation.z800_shutdown:
      friendly_name: 渣渣笔记本关机
    automation.z800_sleep:
      friendly_name: 渣渣笔记本睡眠
    automation.z800_hibernate:
      friendly_name: 渣渣笔记本待机
检测配置:这个技能极为重要,不掌握 在HA【寸步难行
  • 当你修改了ha目录下的【任意配置文件{yaml}】
  • 注意是只要修改保存了文件,不需要重启HA
  • 如果HA已经无法启动了,那就只能用命令来检测配置文件
Hassio,打开ssh,输入下面命令
hassio homeassistant check
Hassbian, 忘记了。 知道的补充
安装了hassctl的
hassctl config
另外:package下面的自动化,检测配置是检测不出来问题的,一检测就全部自动化报一边错误。因此,刚上手 ,自动化最好在automation.yaml下面写。
发表于 2017-9-9 11:12:42 | 显示全部楼层
我看不懂,我只抢沙发
发表于 2017-9-9 13:06:40 | 显示全部楼层
小板凳奉上
发表于 2017-9-9 18:44:28 | 显示全部楼层
这个必须学习了,谢谢老大传授
发表于 2017-9-9 23:42:30 | 显示全部楼层
收下我的膝盖
发表于 2017-9-14 22:29:25 | 显示全部楼层
请教一下,package中的两个yaml如何分组到一个group中?
教程狂人论坛风云人物突出贡献
 楼主| 发表于 2017-9-15 09:16:18 | 显示全部楼层
yaml哪里可以分组到group?
gruop下面可以嵌套group
发表于 2017-9-15 10:17:27 | 显示全部楼层
lidicn 发表于 2017-9-15 09:16
yaml哪里可以分组到group?
gruop下面可以嵌套group
谢谢,昨晚上弄好了,就是在package中新建一个yaml文件单独做分组,完美解决强迫症
教程狂人论坛风云人物突出贡献
 楼主| 发表于 2017-9-15 10:44:02 | 显示全部楼层
BullRom 发表于 2017-9-15 10:17
谢谢,昨晚上弄好了,就是在package中新建一个yaml文件单独做分组,完美解决强迫症 ...
建议按功能模块化
每个yaml一套东西,拿走就移除了一个功能
发表于 2017-9-15 10:50:36 | 显示全部楼层
lidicn 发表于 2017-9-15 10:44
建议按功能模块化
是一个功能或者一个传感器一个yaml,但是如果要把两个传感器组合到一个分组里面(比如房间)。这样是不是就要新建一个yaml分组文件了呀?
GMT+8, 2025-9-5 04:12 , Processed in 1.306125 second(s), 9 queries , MemCached On.
