查看: 5980|回复: 3
飞利浦Hue Zigbee无线调光开关
发表于 2020-8-29 11:10:09 | 显示全部楼层 |阅读模式
看到飞利普的hue无线调光开关是zigbee协议,我想用它接入zigbee2mqtt做调光开关用。
有没人这样尝试过,能不能用呢?
发表于 2020-8-29 23:37:52 | 显示全部楼层
飞利浦 HUE 全系列支持
 楼主| 发表于 2020-8-30 12:00:35 | 显示全部楼层
好的,谢谢
发表于 2020-9-29 09:23:57 | 显示全部楼层
网上查到以下流程,我觉得是可行,等硬件到了试试
[{"id":"1b73ab75.429f65","type":"tab","label":"IKEA Dimmer","disabled":false,"info":""},{"id":"6b59881e.1d59e8","type":"mqtt in","z":"1b73ab75.429f65","name":"dimmer IKEA","topic":"zigbee2mqtt/dimmer1","qos":"0","datatype":"json","broker":"2fe33b3d.43a524","x":130,"y":90,"wires":[["3173bc98.9870c4","30487862.5006a8"]]},{"id":"3173bc98.9870c4","type":"rbe","z":"1b73ab75.429f65","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":290,"y":90,"wires":[["718e4213.fc089c"]]},{"id":"c00103c1.b8a8","type":"function","z":"1b73ab75.429f65","name":"Set Brightness","func":"var brightness = msg.payload.brightness;\n\nmsg.payload = {\n    //\"state\": \"ON\",\n    \"brightness\": brightness\n    \n}\nreturn msg;","outputs":1,"noerr":0,"x":665,"y":90,"wires":[["b839b692.dea8d8"]]},{"id":"b839b692.dea8d8","type":"mqtt out","z":"1b73ab75.429f65","name":"spotlight","topic":"zigbee2mqtt/spotlight1/set","qos":"","retain":"","broker":"2fe33b3d.43a524","x":870,"y":90,"wires":[]},{"id":"718e4213.fc089c","type":"delay","z":"1b73ab75.429f65","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"2","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":460,"y":90,"wires":[["c00103c1.b8a8","b8f5f451.d30b68"]]},{"id":"30487862.5006a8","type":"debug","z":"1b73ab75.429f65","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":390,"y":225,"wires":[]},{"id":"b8f5f451.d30b68","type":"debug","z":"1b73ab75.429f65","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":655,"y":180,"wires":[]},{"id":"2fe33b3d.43a524","type":"mqtt-broker","z":"","name":"","broker":"192.168.1.132","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
GMT+8, 2025-9-10 05:58 , Processed in 0.275380 second(s), 9 queries , MemCached On.
