楼主: hunterfox
[进阶教程] 搞定人脸识别baiduface 分享一下
发表于 2021-7-12 11:02:06 | 显示全部楼层
请教下大神,这个报错是什么情况啊?是没有弄好吗?
日志如下
Logger: homeassistant.helpers.entity
Source: custom_components/baidu_face/sensor.py:169
Integration: baidu_face (documentation)
First occurred: 上午10:25:01 (1 occurrences)
Last logged: 上午10:25:01
Update for sensor.face_indentity fails
  File "/data/data/com.termux/files/home/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/entity.py", line 316, in async_update_ha_state
    await self.async_device_update()
  File "/data/data/com.termux/files/home/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/entity.py", line 524, in async_device_update
    raise exc
  File "/data/data/com.termux/files/usr/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/data/data/com.termux/files/home/.homeassistant/custom_components/baidu_face/sensor.py", line 138, in update
    self.face_searching()
  File "/data/data/com.termux/files/home/.homeassistant/custom_components/baidu_face/sensor.py", line 169, in face_searching
    ret = self._baidu_client.multiSearch(encode_img, image_type, self._group_list, self._options)
  File "/data/data/com.termux/files/home/homeassistant/lib/python3.8/site-packages/aip/face.py", line 100, in multiSearch
    return self._request(self.__multiSearchUrl, json.dumps(data, ensure_ascii=False), {
  File "/data/data/com.termux/files/home/homeassistant/lib/python3.8/site-packages/aip/base.py", line 100, in _request
    obj = self._proccessResult(response.content)
  File "/data/data/com.termux/files/home/homeassistant/lib/python3.8/site-packages/aip/base.py", line 145, in _proccessResult
    return json.loads(content.decode()) or {}
  File "/data/data/com.termux/files/usr/lib/python3.8/json/__init__.py", line 357, in loads
    return _default_decoder.decode(s)
  File "/data/data/com.termux/files/usr/lib/python3.8/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/data/data/com.termux/files/usr/lib/python3.8/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
发表于 2021-7-13 19:36:37 | 显示全部楼层
多谢大佬分享!
发表于 2021-8-3 10:17:43 | 显示全部楼层
希望可以用
发表于 2021-9-1 12:21:53 | 显示全部楼层
楼主可以分享下,你的nodered设置吗
发表于 2021-9-2 17:40:51 | 显示全部楼层
这是个好东西
发表于 2021-9-27 16:49:30 | 显示全部楼层
还没有试过,不知道能不能成功
发表于 2021-11-9 22:36:08 | 显示全部楼层
请问用的什么摄像头!通过什么方式获取的图片
 楼主| 发表于 2021-11-9 23:22:54 | 显示全部楼层
萤石。  群晖,API 获取的
发表于 2021-11-10 00:08:03 | 显示全部楼层
膜拜大佬。
我不生产技术,我只是技术的搬运工。
发表于 2022-2-18 00:41:17 | 显示全部楼层
有没有更长细点的呢?保姆级的,好想学
GMT+8, 2025-9-16 02:41 , Processed in 0.298078 second(s), 12 queries , MemCached On.
