查看: 8526|回复: 8
[智能音箱] 求助小爱音箱黑板,无法开启sh
发表于 2020-5-29 19:59:52 | 显示全部楼层 |阅读模式
GXL:BL1:9ac50e:a1974b;FEAT:ADFC318C;POC:3;RCY:0;EMMC:800;NAND:0;READ:0;0.0;CHK:0;
TE: 26893
BL2 Built : 18:43:23, Sep  8 2017.
gxl g5190619 - xiaobo.gu@droid12
rn5t618_power_init
Board ID = 0
CPU clk: 1200MHz
DQS calibration enabled
DDR scramble enabled
DDR3 chl: Rank0 @ 792MHz
af_vref ddr_training_win: rank: 0 21 00 51 45 14 76 21 00 53 4a 19 7b 1f 00 50 4c 18 80 27 00 5a 47 13 7c 595  rank: 1 34 00 51 0d 14 76 35 00 53 12 19 7b 36 00 50 12 18 80 37 00 5a 0d 13 7c 595
af_vref ddr_bist_window:  rank: 0 1f 03 44 33 20 61 1f 07 43 37 25 5c 1d 02 39 39 23 62 24 03 43 34 22 63 595   - PASS
Rank0: 256MB(auto)-2T-11
AddrBus test pass!
NAND init
read start page:00000000
page :00000500
succeed in getting one bbt block!
page :00000540
page :00000580
page :000005c0
select bbt block:00000014
select page:00000001
select page:00000000
bbt status: 00000000000000000000000000000000
Load fip header from NAND, src: 0x00020000, des: 0x01400000, size: 0x00004000
read start page:00000041
New fip structure!
Load bl30 from NAND, src: 0x00024000, des: 0x01100000, size: 0x0000d600
read start page:00000049
Load bl31 from NAND, src: 0x00034000, des: 0x05100000, size: 0x00017400
read start page:00000069
Load bl33 from NAND, src: 0x0004c000, des: 0x01000000, size: 0x00081c00
read start page:00000099
NOTICE:  BL3-1: v1.0(debug):2da3090
NOTICE:  BL3-1: Built : 16:05:52, Jan 19 2017
aml log : bl31 normal boot !
mpu_config_enable:ok
[Image: gxl_v1.1.3170-f392be9 2017-01-04 10:51:57 yun.cai@droid06]
OPS=0xf2
19 c8 bc 21 33 37 db 4c e7 13 d4 65 [0.485475 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g85a2387-dirty (Sep 19 2017 - 19:00:12)
DRAM:  256 MiB
Relocation Offset is: 0ef38000
register usb cfg[0][1] = 000000000ffa1290
NAND:  nand id: 152 218
256MiB, SLC, page size: 2048, OOB size: 64
Creating 1 MTD partitions on "A revision NAND 2Gib TC58BVG1S3HTA00 ":
0x000000000000-0x000000200000 : "nandboot"
nand id: 152 218
Creating 5 MTD partitions on "A revision NAND 2Gib TC58BVG1S3HTA00 ":
0x000000800000-0x000001800000 : "boot0"
0x000001800000-0x000002800000 : "boot1"
0x000002800000-0x000008880000 : "system0"
0x000008880000-0x00000e8c0000 : "system1"
0x00000e8c0000-0x000010000000 : "data"
MMC:   In:    serial
Out:   serial
Err:   serial
[burnup]Rd:Up sz 0x800 to align 0x1000
[burnup]run cmd[store  read boot0 0x1000000  0x0  0x1000]
[burnup]Read end.
[burnup]run cmd[store  read boot0 0x1988800  0x988800  0x8000]
[burnup]Read end.
amlkey_init() enter!
amlkey_init() storagekey_info.buffer=0000000005080000, storagekey_info.size = 7ffc!
[KM]Error:f[key_unify_init]L177:Device[1] init failed, err=-22
InUsbBurn
noSof
Hit Enter or space or Ctrl+C key to stop autoboot -- :  0
HAVE SN Code ...
Saving Environment to aml-storage...
[burnup]run cmd[store  read boot0 0x1080000  0x0  0x100000]
[burnup]Read end.
[burnup]Rd:Up sz 0x8905be to align 0x1000
[burnup]run cmd[store  read boot0 0x1180000  0x100000  0x891000]
[burnup]Read end.
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
load dtb from 0x1000000 ......
   Loading Kernel Image(COMP_NONE) ... OK
   kernel loaded at 0x01080000, end = 0x018bbc88
[rsvmem] no check for rsvmem, should check int kernel
   Loading Ramdisk to 0bdda000, end 0bf25810 ... OK
   Loading Device Tree to 000000000bdcf000, end 000000000bdd9dbd ... OK
Starting kernel ...
uboot time: 1627748 us
[    0.136536@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb4)
[    0.139009@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb4)
[    0.147242@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb4)
[    0.155109@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb4)
domain-0 init dvfs: 4
[BL31]: tee size: 0
[BL31]: tee size: 0
[BL31]: tee size: 0
[BL31]: tee size: 0
WARNING: Unimplemented Sip Call: 0x82000036
[▒get key is 0x00 , curr_boot is boot0
Booting from boot0
UBI device number 0, total 768 LEBs (97517568 bytes, 93.0 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
/dev/mtd3 is ready now.
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
Please press Enter to activate this console.
[    4.860501@0] compat: exports duplicate symbol woken_wake_function (owned by kernel)
mico login:
回车后显示mico登录:为什么我回车后会大佬的不一样,是新版固件的问题吗,看上面还有故障模式和debug模式
我后来按F +回车进到故障模式出不来,按什么都乜有反应,怎么办?求救大神
 楼主| 发表于 2020-5-29 23:16:40 | 显示全部楼层
已经根据大佬的md5算法找到密码,跟大佬接入ha的教程不一样,还要研究怎么接入
发表于 2020-5-30 13:49:20 | 显示全部楼层
我的还可以呀
 楼主| 发表于 2020-5-30 14:01:41 | 显示全部楼层
恩,密码搞定了,算出来的无法更改,不过重启还是会还原密码
 楼主| 发表于 2020-5-30 15:30:37 | 显示全部楼层
<div class="blockcode"><blockquote>login as: root
[email protected]'s password:
BusyBox v1.23.2 (2019-11-11 03:44:52 UTC) built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 CHAOS CALMER (Chaos Calmer, unknown)
  * 1 1/2 oz Gin            Shake with a glassful
  * 1/4 oz Triple Sec       of broken ice and pour
  * 3/4 oz Lime Juice       unstrained into a goblet.
  * 1 1/2 oz Orange Juice
  * 1 tsp. Grenadine Syrup
root@mico:~# curl -s "https://raw.githubusercontent.com/FlashSoft/mico/dev/insta
ll.sh?`date +%s`" > /root/install.sh
root@mico:~# sh /root/install.sh
     欢迎使用'小爱拦截器'安装工具 v0.9(2018.10.31)
     本工具通过拦截小爱的识别词和响应词
     把拦截的请求转发给NodeRed服务进行自定义设备的操作
     论坛地址 https://bbs.hassbian.com/thread-5110-1-1.html
[!!!注意] 需要先有NodeRed服务并且提供了/miai这样的get接口(导入论坛提供的流就好)
请输入NodeRed服务地址,默认值[http://192.168.1.1:1880]:
http://192.168.10.3:1880
请输入你的NodeRed的账号和密码,如果没有密码请直接回车:
格式为 账号:密码
[!!!注意] asr拦截词为你对小爱自己说的话
请输入asr拦截词,多个拦截词使用|分割,默认值为[空]:
[!!!注意] res拦截词为小爱对你的响应内容
请输入res拦截词,多个拦截词使用|分割,默认值为[空]:
请输入响应拦截词的更新频率,单位秒,0为不更新,默认值[0]:
      NodeRed服务地址: http://192.168.10.3:1880
      NodeRed账号密码: 无密码
            asr拦截词: 无拦截词
            res拦截词: 无拦截词
       拦截词更新频率: 20
以上信息是否正确?任意键继续安装,ctrl+c取消安装:
开始验证nodered访问是否通畅
状态信息: HTTP/1.1 200 OK
验证通过
小爱固件版本: 新版固件
部署启动脚本
安装完毕
可以使用/etc/init.d/mico_enable start 启动小爱拦截器
root@mico:~# /etc/init.d/mico_enable start
root@mico:~# ===============================================================
      NodeRed账号密码: 无密码
            asr拦截词: 无拦截词
            res拦截词: 无拦截词
       拦截词更新频率: 20
开始验证NodeRed访问是否通畅
验证通过
== 更新关键词 | asr关键词内容: 早安|晚安|室内空气 | res关键词内容: soundboxContr                                 olTV
root@mico:~# == 更新关键词 | asr关键词内容: 早安|晚安|室内空气 | res关键词内容: soundboxControlTV
发表于 2020-5-31 12:38:50 | 显示全部楼层
怎样判断黑色还是绿色主板?
 楼主| 发表于 2020-6-1 00:41:39 | 显示全部楼层
anmonkey 发表于 2020-5-31 12:38
怎样判断黑色还是绿色主板?
灰色包装是
发表于 2020-6-1 10:24:16 | 显示全部楼层
这个,估计很难找了吧
 楼主| 发表于 2020-6-3 10:59:09 | 显示全部楼层
anmonkey 发表于 2020-6-1 10:24
这个,估计很难找了吧
对,我有两个,等实验成功就出一个
GMT+8, 2025-9-15 03:20 , Processed in 0.667328 second(s), 14 queries , MemCached On.
