冬瓜HA 发表于 2026-8-15 12:15
要把你的dtb放进去才行。你接串口,上电后的日志放在这
MMC: mmc@fe2b0000: 1, mmc@fe2c0000: 2, mmc@fe310000: 0Loading Environment from nowhere... OKIn: serial@fe660000Out: serial@fe660000Err: serial@fe660000Model: KICKPI K11C V12SoC: RK3566Net: No ethernet found.Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevsSeq Method State Uclass Part Name Filename--- ----------- ------ -------- ---- ------------------------ ----------------Scanning global bootmeth 'efi_mgr':Card did not respond to voltage select! : -110Missing RNG device for EFI_RNG_PROTOCOL 0 efi_mgr ready (none) 0 <NULL> ** Booting bootflow '<NULL>' with efi_mgrLoading Boot0000 'mmc 1' failedLoading Boot0001 'mmc 0' failedEFI boot manager: Cannot load any imageBoot failed (err=-14)Scanning bootdev 'mmc@fe2b0000.bootdev': 1 script ready mmc 1
mmc@fe2b0000.bootdev.part /boot.scr** Booting bootflow 'mmc@fe2b0000.bootdev.part_1' with scriptstdin=serial@fe660000## Error inserting "stdin" variable, errno=22stdin=serial@fe660000==[Uboot: boot.scr]======================boot devtype: mmc:1switch to partitions #0, OKmmc1 is current deviceloading env...MMC read: dev # 1, block # 1736704, count 64 ... 64 blocks read: OK## Error: Can't overwrite "ethaddr"himport_r: can't insert "ethaddr=3e:1d:19:67:49:f7" into hash table## Error: Can't overwrite "serial#"himport_r: can't insert "serial#=afe094e5926b7e2b" into hash table0 bytes read in 1 ms (0 Bytes/s)Unknown command 'fileenv' - try 'help'36 bytes read in 1 ms (35.2 KiB/s)Loading standard device tree dtbs/rk3566-kickpi-k11c-v12.dtb167048 bytes read in 17 ms (9.4 MiB/s)Working FDT set to 12000000Unknown command 'setexpr' - try 'help'Trying to boot slot A, 3 attempts remaining. Loading kernel ...Can't set block deviceUnknown command 'setexpr' - try 'help'Trying to boot slot B, 3 attempts remaining. Loading kernel ...Can't set block deviceNo valid slot found, resetting tries to 3storing env...MMC write: dev # 1, block # 1736704, count 64 ... 64 blocks written: OKresetting ...
