查看: 669|回复: 6
[技术探讨] ESPHOME编译环境问题连接设备问题请教
发表于 2025-1-22 16:41:54 | 显示全部楼层 |阅读模式
请教各位大神,我在homeassistant 搭建的ESPHOME编译环境创建了一个8266开关项目,成功刷机后开关正常使用,现在开关在开发环境中显示为离线状态,但在“设备与服务”中为在线状态,可正常控制和使用,现在如何才能将天关重新连到编译环节中进行代码修改,不想把开关拆下来刷固件,太麻烦了,请各位大神指点,谢谢,谢谢。
发表于 2025-1-22 17:39:13 | 显示全部楼层
当时如果有开网页功能就能OTA
发表于 2025-1-23 10:01:04 | 显示全部楼层
esphome 的 docker 端口开了吗?在5353通信的看错了没用docker,总之先检查是不是通信问题,把配置文件都放上来让大伙看看
 楼主| 发表于 2025-1-23 15:07:07 | 显示全部楼层
ganguotu 发表于 2025-1-23 10:01
esphome 的 docker 端口开了吗?在5353通信的看错了没用docker,总之先检查是不是通信问题,把配置文件都放 ...
#########  左一面板  ####################
substitutions:
  # Modify variables based on your settings
  devicename: "diningroom"
esphome:
  platform: esp8266
  board: esp01_1m
packages:
  wifi: !include common/wifi.yaml
# Enable logging
logger:
captive_portal:
switch:
  - platform: gpio
    name: '${devicename}_sw1'    #  #
    pin:
      number: 13
      inverted: yes
  - platform: gpio
    name: '${devicename}_sw2'   #入户门灯双控  #
    pin:
      number: 12
      inverted: yes
  - platform: gpio
    pin:
      number: 16
      inverted: yes
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO2
    device_class: opening
    filters:
      - delayed_on_off: 50ms
    on_state:
      then:
       - switch.toggle: kaiguan1
  - platform: homeassistant    #这是配置双控 入户灯#
    entity_id: switch.livingroom_main_sw1
  - platform: gpio
    pin:
      number: GPIO4
    filters:
      - delayed_on: 50ms
      - delayed_off: 50ms
    on_state:
      then:
        - logger.log: "---------- 双控开关"
        - if:
            condition:
              switch.is_on: kaiguan2
              # switch.is_on: kaiguan2 #   无法实验取消本行# 屏蔽下面几行
              #- homeassistant.service:
              #     service: switch.is_on
              #     data:
              #       entity_id: switch.livingroom_main_sw1
            then:
              - switch.turn_off: kaiguan2
                  service: switch.turn_off
                  data:
            else:
              - switch.turn_on: kaiguan2
                  service: switch.turn_on
                  data:
  - platform: gpio
    pin:
      number: GPIO5
      mode: INPUT_PULLUP
    filters:
      - delayed_on_off: 100ms
    on_state:
      then:
        - switch.toggle: kaiguan3
  - platform: wifi_signal
    name: ${devicename} wifi signal
    update_interval: 600s
time:
# Text sensors with general information.
text_sensor:
  - platform: wifi_info
    ip_address:
wifi.yaml文件
wifi:
  ssid: Hass.io
  password: xxxxxxx
#  domain: .yourdomain.lan
#  fast_connect: true
#  reboot_timeout: 15min
  power_save_mode: none
  ap:
    ssid: "${devicename} ap"
    password: "xxxxxx"
api:
  reboot_timeout: 0s # 設定未連線 Home Assistant 時重新啟動時間 0s為不啟動
  encryption:
    key: "xxxxx"
ota:
  - platform: esphome
    password: "xxxxx"
 楼主| 发表于 2025-1-23 15:10:19 | 显示全部楼层
bd4wbw 发表于 2025-1-22 17:39
当时如果有开网页功能就能OTA
开了OTA的,我是想重新连到开发环境方便一些。
zad
发表于 2025-1-23 15:54:13 | 显示全部楼层
可能是设备的mdns模块有问题,没刷好,内网直接ping设备的ip应该可以ping通。试一下重启设备,之后如果还连接不上的话,看直接在yaml文件里填上设备的IP,或者通过esphome命令行upload命令重新刷一次,命令行可以直接指定设备ip。https://community.home-assistant ... or-ota-flash/140913
 楼主| 发表于 2025-1-24 15:17:20 | 显示全部楼层
zad 发表于 2025-1-23 15:54
可能是设备的mdns模块有问题,没刷好,内网直接ping设备的ip应该可以ping通。试一下重启设备,之后如果还连 ...
手动IP后成功更新了,
GMT+8, 2025-7-21 13:30 , Processed in 0.214400 second(s), 12 queries , MemCached On.
