查看: 3376|回复: 2
[求助] 智米电风扇插件无法正常运行
论坛分享达人
发表于 2017-8-8 12:14:08 | 显示全部楼层 |阅读模式
2017-08-08 12:10:23 ERROR (Thread-4) [miio.miio] got error when receiving: timed out
2017-08-08 12:10:23 ERROR (MainThread) [homeassistant.components.fan] Error while setting up platform smart_mi_fan
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for
    return fut.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
    result = self.fn(*self.args, **self.kwargs)
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 76, in setup_platform
    SmartMiFan(hass, name, host, token),
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 145, in __init__
    self._state_attrs = self.fan_get_prop()
  File "/home/homeassistant/.homeassistant/custom_components/fan/smart_mi_fan.py", line 379, in fan_get_prop
    prop = self.fan.send("get_prop", ["temp_dec","humidity","angle","speed","poweroff_time","power","ac_power","battery","angle_enable","speed_level","natural_level","child_lock","buzzer","led_b"])
  File "/srv/homeassistant/lib/python3.4/site-packages/miio/miio.py", line 128, in send
    data, addr = s.recvfrom(1024)
socket.timeout: timed out
2017-08-08 12:10:23 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template current_smart_mi_fan_shake_head_angle, the state is unknown.
2017-08-08 12:10:23 WARNING (MainThread) [homeassistant.components.sensor.template] Could not render template current_smart_mi_fan_speed, the state is unknown.
发表于 2017-9-9 14:58:06 | 显示全部楼层
小米遥控器同样:
2017-09-09 14:55:10 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform chuangmi_ir
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
  File "/usr/local/Cellar/python3/3.6.2/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/local/Cellar/python3/3.6.2/Frameworks/Python.framework/Versions/3.6/lib/python3.6/asyncio/futures.py", line 245, in result
  File "/usr/local/Cellar/python3/3.6.2/Frameworks/Python.framework/Versions/3.6/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/Users/tianyucheng/.homeassistant/custom_components/switch/chuangmi_ir.py", line 103, in setup_platform
    ir_remote = miio.device(host, token)
  File "/Users/tianyucheng/.homeassistant/deps/lib/python/site-packages/miio/miio.py", line 16, in __init__
    self.token = bytes.fromhex(token)
ValueError: non-hexadecimal number found in fromhex() arg at position 0
论坛分享达人
 楼主| 发表于 2017-8-13 13:58:17 | 显示全部楼层
同样的错误 0.51.1下依旧
GMT+8, 2025-6-29 11:37 , Processed in 1.113908 second(s), 24 queries .
