查看: 4069|回复: 1
[求助] 一键安装HASSIO失败
发表于 2019-8-13 23:52:09 | 显示全部楼层 |阅读模式
########################### hassio log ###########################
19-08-13 15:26:05 INFO (MainThread) [__main__] Initialize Hass.io setup
19-08-13 15:26:05 INFO (MainThread) [hassio.docker.network] Can't find Hass.io network, create new network
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Home Assistant configuration folder /data/homeassistant
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Hass.io SSL/TLS folder /data/ssl
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on data folder /data/addons/data
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on local repository folder /data/addons/local
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on git repositories folder /data/addons/git
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Hass.io temp folder /data/tmp
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Hass.io backup folder /data/backup
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Hass.io share folder /data/share
19-08-13 15:26:06 INFO (MainThread) [hassio.bootstrap] Create Hass.io Apparmor folder /data/apparmor
19-08-13 15:26:07 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 173
19-08-13 15:26:07 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
19-08-13 15:26:09 INFO (MainThread) [__main__] Setup HassIO
19-08-13 15:26:09 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
19-08-13 15:26:09 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-08-13 15:26:09 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
19-08-13 15:26:09 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-08-13 15:26:09 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
19-08-13 15:26:09 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Errorrg.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-08-13 15:26:09 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-08-13 15:26:09 INFO (MainThread) [hassio.host.info] Update local host information
19-08-13 15:26:09 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-08-13 15:26:09 INFO (MainThread) [hassio.host.services] Update service information
19-08-13 15:26:09 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-08-13 15:26:10 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: set()
19-08-13 15:26:10 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on host
19-08-13 15:26:10 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/raspberrypi3-homeassistant with version 0.97.2
19-08-13 15:26:10 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/home-assistant/hassio-addons repository
19-08-13 15:26:10 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/hassio-addons/repository repository
########################### homeassistant log ###########################
Error: No such container: homeassistant
########################### END ###########################
homeassistant 启动超时,请检查上方日志....
这是日志 看不懂
超级版主
Nero
发表于 2019-8-14 08:49:04 | 显示全部楼层
重启就行了
Nero
GMT+8, 2025-9-21 03:01 , Processed in 1.002242 second(s), 11 queries , MemCached On.
