查看: 717|回复: 6
冬瓜伴侣,小白滴神
发表于 2025-8-30 17:11:23 | 显示全部楼层 |阅读模式
所有系统完美升级最新!!
2025-08-30 16:54:33.541 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2025.8.3
2025-08-30 16:54:33.543 INFO (MainThread) [supervisor.docker.interface] Updating image r.hassbus.com/home-assistant/odroid-c4-homeassistant:2025.6.1 to r.hassbus.com/home-assistant/odroid-c4-homeassistant:2025.8.3
2025-08-30 16:54:33.544 INFO (MainThread) [supervisor.docker.interface] Downloading docker image r.hassbus.com/home-assistant/odroid-c4-homeassistant with tag 2025.8.3.
2025-08-30 16:59:33.255 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping homeassistant application
2025-08-30 17:00:02.450 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning homeassistant application
2025-08-30 17:00:03.699 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2025-08-30 17:00:04.699 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant r.hassbus.com/home-assistant/odroid-c4-homeassistant with version 2025.8.3
2025-08-30 17:00:04.700 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2025-08-30 17:00:48.880 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-08-30 17:00:49.909 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-08-30 17:00:50.085 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2025-08-30 17:01:56.825 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2025-08-30 17:01:56.826 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2025-08-30 17:01:56.827 INFO (MainThread) [supervisor.homeassistant.core] Successfully started Home Assistant 2025.8.3
2025-08-30 17:01:56.976 INFO (SyncWorker_6) [supervisor.docker.manager] Cleanup images: ['r.hassbus.com/home-assistant/odroid-c4-homeassistant:2025.6.1']
2025-08-30 17:04:21.208 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_ssh
2025-08-30 17:04:21.219 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_ssh
2025-08-30 17:04:21.230 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_ssh
2025-08-30 17:04:21.258 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from core_sshfile:///C:/Users/GM/Pictures/Screenshots/%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202025-08-30%20171006.png
发表于 2025-9-6 18:09:22 | 显示全部楼层
壁纸可以发一下吗,楼主
mhbj 手机认证
发表于 2025-9-1 08:34:16 | 显示全部楼层
a2258555 发表于 2025-8-31 23:27
我是南方电网哦 HAC里面就有
好吧,我用不了
 楼主| 发表于 2025-8-31 23:27:20 | 显示全部楼层
mhbj 发表于 2025-8-30 22:42
请教下,这个国家电网是怎么整啊,我用了sgcc的集成,日志有数据,但根本没有实体 ...
我是南方电网哦 HAC里面就有
发表于 2025-8-31 12:43:06 | 显示全部楼层
稳定好用
mhbj 手机认证
发表于 2025-8-30 22:42:27 来自手机 | 显示全部楼层
 楼主| 发表于 2025-8-30 17:15:28 | 显示全部楼层
感谢各路大佬的教程
GMT+8, 2025-9-17 03:00 , Processed in 0.255263 second(s), 14 queries , MemCached On.
