查看: 7289|回复: 1
[已解决] ubuntu docker hassio 连不上了,event清单,....
发表于 2018-1-29 12:00:46 | 显示全部楼层 |阅读模式
一晚上过去 就连不上了,也不是防火墙的问题,应该怎么解决?
目测是 Home-Assistant API的问题。
18-01-30 04:16:15 INFO (MainThread) [hassio.core] Hass.io is up and running
18-01-30 04:21:15 WARNING (MainThread) [hassio.tasks] Watchdog miss API response from Home-Assistant
18-01-30 04:26:15 ERROR (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant API!
18-01-30 04:26:15 INFO (SyncWorker_6) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
进log看了一下,是yaml文件有问题,改好了
 楼主| 发表于 2018-1-30 13:46:12 | 显示全部楼层
更新了一下图,有人帮忙看一下吗
GMT+8, 2025-9-17 04:37 , Processed in 0.411272 second(s), 13 queries , MemCached On.
