查看: 3361|回复: 10
[求助] 如何在界面上显示开着的实体
PAUL
发表于 2023-3-2 15:10:21 | 显示全部楼层 |阅读模式
我想在界面上显示正在打开的灯或开关,应该怎么设置呢?
PAUL
 楼主| 发表于 2023-3-3 10:53:32 | 显示全部楼层
Necroneco 发表于 2023-3-2 19:26
不想手动填所有的实体id,可以试试 auto-entities
https://github.com/thomasloven/lovelace-auto-entities ...
谢谢,我看了这个需要装插件才能实现,比较而言还是手动填上去来的快一点
发表于 2023-3-2 19:26:15 来自手机 | 显示全部楼层
PAUL
 楼主| 发表于 2023-3-2 16:14:55 | 显示全部楼层
最后的显示效果
PAUL
 楼主| 发表于 2023-3-2 16:10:20 | 显示全部楼层
谢谢,我也参考了下官网的文档,应该是需要把所有实体一个一个列出来,才能实现。我把switch和light都加上了。
type: entity-filter
entities:
  - light.gateway_light_286c07f0c4e5
  - light.gateway_light_7c49eb1a6730
  - light.ke_ting_deng
  - light.lumi_v3_c4e5_light
  - light.yang_tai_deng
  - light.zimi_dhkg02_6573_indicator_light
  - switch.1f_woshi
  - switch.94f827836573_channel_1
  - switch.94f827836573_channel_2
  - switch.94f827836573_led
  - switch.94f827836573_wireless_1
  - switch.94f827836573_wireless_2
  - switch.bingui
  - switch.ciwo_light
  - switch.huawei_router_wifi_6_twt
  - switch.isa_df3_b3d3_switch_status
  - switch.lumi_v1_1bf5_switch
  - switch.my_nas
  - switch.plug_158d00015d1bf5
  - switch.plug_158d00024ea638
  - switch.plug_158d00024f2a83
  - switch.s1_s1
  - switch.s1_s2
  - switch.s1_s3
  - switch.s1_s4
  - switch.s2_s1
  - switch.s2_s2
  - switch.s2_s3
  - switch.s2_s4
  - switch.s3_s1
  - switch.s3_s2
  - switch.s3_s3
  - switch.s3_s4
  - switch.sp_mini
  - switch.woshi_light
  - switch.xiaomi_s12_671d_sleep_mode
  - switch.zimi_dhkg02_6573_left_switch_service
  - switch.zimi_dhkg02_6573_right_switch_service
state_filter:
  - 'on'
card:
  type: entities
  title: 正在运行的设备
发表于 2023-3-2 15:54:10 | 显示全部楼层
PAUL 发表于 2023-3-2 15:45
state_filter:怎么填,填on吗?
type: entity-filter
state_filter:
  - operator: '=='
    value: 'on'
  - operator: <
    value: 10
entities:
  - entity: climate.gr_ac_11002_02_302f
    state_filter:
      - operator: '!='
        value: 'off'
  - media_player.smartir_tv
  - entity: cover.curtain
    state_filter:
      - operator: '=='
        value: open
  - sensor.curtain_battery
  - sensor.tz3000_4fjiwweb_ts004f_battery
card:
  type: entities
  title: 关注的设备
show_empty: false
你参考下
参与人数 1金钱 +20 收起 理由
dscao + 20 纳尼,还有这种操作?
PAUL
 楼主| 发表于 2023-3-2 15:47:57 | 显示全部楼层
entities: 字段能不能按类型添加。。。
PAUL
 楼主| 发表于 2023-3-2 15:45:01 | 显示全部楼层
bugensui 发表于 2023-3-2 15:43
可以是不同类型,
发表于 2023-3-2 15:43:44 | 显示全部楼层
PAUL 发表于 2023-3-2 15:42
type: entity-filter
entities:
  - sensor.zhi_neng_yao_kong_temperature
可以是不同类型,
PAUL
 楼主| 发表于 2023-3-2 15:42:29 | 显示全部楼层
type: entity-filter
entities:
  - sensor.my_nas_library_dian_ying
  - sensor.my_nas_library_yan_chang_hui
state_filter:
  - '19.4'
card:
  type: entities
看上去这是需要实体都是同一种类型吧,而且还需要把所有实体id都填进去。配置起来太麻烦了
GMT+8, 2025-9-7 05:04 , Processed in 0.081467 second(s), 12 queries , MemCached On.
