查看: 5335|回复: 12
[技术探讨] ha可以设置定时重启吗?
发表于 2023-1-4 03:37:19 来自手机 | 显示全部楼层 |阅读模式
有些灯带用的通断器。有时关闭了。重新开启后家庭就灯带没法重新连接。只能重启ha,所以想弄定时重启一次,让它可以恢复状态
发表于 2024-4-17 11:48:46 | 显示全部楼层
relliky 发表于 2024-4-16 22:52
可以,去service里面找,有个addon restart的service,选择z2m
找到了,
发表于 2024-4-16 22:52:30 | 显示全部楼层
yuyanhui1988 发表于 2024-4-16 19:56
我感觉Z2M加载项有点问题,能设置成定时重启吗?
发表于 2024-4-16 19:56:09 | 显示全部楼层
relliky 发表于 2023-1-4 23:42
很多时候问题出在各种地方,而且也不一定HA重启有用,换灯带固然好,但是还是要增加成本的。
比如localtu ...
发表于 2023-1-4 23:42:44 | 显示全部楼层
fung1006 发表于 2023-1-4 15:33
治標不治本
如果有設備每小時都有問題,難度你要每小時重啟一次HA?
比如localtuya的wifi灯泡比tuya集成容易掉线,需要重启HA,重载集成整个集成会崩溃。
hue的灯泡话掉线了需要重新断电开关,重启HA也不管用,这个时候就需要写个开关墙壁开关的自动化。
我有一个自动化专门用来重启HA针对localtuya的设备的,用来查错用的,实在因为wifi信号不好容易掉线的就从localtuya换到tuya集成了,除了换灯泡也没太好的办法。
  - alias: L- Restart HA When localtuya lights Are Offline
    mode: single
    trigger:
      - platform: state
        entity_id:
        #- light.ground_toilet_bulb_1_localtuya
        - light.ground_toilet_bulb_2_localtuya
        #- light.kitchen_spotlight_bulb_1_localtuya
        - light.kitchen_spotlight_bulb_2_localtuya
        - light.kitchen_spotlight_bulb_3_localtuya
        - light.kitchen_spotlight_bulb_4_localtuya
        - light.kitchen_spotlight_bulb_5_localtuya
        - light.kitchen_spotlight_bulb_6_localtuya
        - light.kitchen_spotlight_bulb_7_localtuya
        - light.master_room_lamp_1_localtuya
        - light.master_room_lamp_2_localtuya
        - light.guest_toilet_bulb_1_localtuya
        - light.guest_toilet_bulb_2_localtuya
        - light.guest_toilet_bulb_3_localtuya
        - light.living_room_landing_light_1_localtuya
        - light.living_room_3_head_lamp_1_localtuya
        - light.living_room_3_head_lamp_2_localtuya
        - light.living_room_3_head_lamp_3_localtuya
      - platform: time_pattern
        minutes: "5"
    condition:
      #  A tuya device is online but one of its localtuya integration is offline and needs to be reloaded
      - condition: or
        conditions:
          # Ground toilet 1/kitchen 1 have a large packet loss rate due to poor wifi connection
          #- "{{(states.light.ground_toilet_bulb_1_localtuya.state == 'unavailable')        and (states.light.ground_toilet_bulb_1_tuya.state != 'unavailable')}}"
          - "{{(states.light.ground_toilet_bulb_2_localtuya.state == 'unavailable')        and (states.light.ground_toilet_bulb_2_tuya.state != 'unavailable')}}"
          #- "{{(states.light.kitchen_spotlight_bulb_1_localtuya.state == 'unavailable')    and (states.light.kitchen_spotlight_bulb_1_tuya.state != 'unavailable')}}"
          - "{{(states.light.kitchen_spotlight_bulb_2_localtuya.state == 'unavailable')    and (states.light.kitchen_spotlight_bulb_2_tuya.state != 'unavailable')}}"
          - "{{(states.light.kitchen_spotlight_bulb_3_localtuya.state == 'unavailable')    and (states.light.kitchen_spotlight_bulb_3_tuya.state != 'unavailable')}}"
          - "{{(states.light.kitchen_spotlight_bulb_4_localtuya.state == 'unavailable')    and (states.light.kitchen_spotlight_bulb_4_tuya.state != 'unavailable')}}"
          - "{{(states.light.kitchen_spotlight_bulb_5_localtuya.state == 'unavailable')    and (states.light.kitchen_spotlight_bulb_5_tuya.state != 'unavailable')}}"
          - "{{(states.light.kitchen_spotlight_bulb_6_localtuya.state == 'unavailable')    and (states.light.kitchen_spotlight_bulb_6_tuya.state != 'unavailable')}}"
          - "{{(states.light.kitchen_spotlight_bulb_7_localtuya.state == 'unavailable')    and (states.light.kitchen_spotlight_bulb_7_tuya.state != 'unavailable')}}"
          - "{{(states.light.master_room_lamp_1_localtuya.state == 'unavailable')          and (states.light.master_room_lamp_1_tuya.state != 'unavailable')}}"
          - "{{(states.light.master_room_lamp_2_localtuya.state == 'unavailable')          and (states.light.master_room_lamp_2_tuya.state != 'unavailable')}}"
          - "{{(states.light.guest_toilet_bulb_1_localtuya.state == 'unavailable')         and (states.light.guest_toilet_bulb_1_tuya.state != 'unavailable')}}"
          - "{{(states.light.guest_toilet_bulb_2_localtuya.state == 'unavailable')         and (states.light.guest_toilet_bulb_2_tuya.state != 'unavailable')}}"
          - "{{(states.light.guest_toilet_bulb_3_localtuya.state == 'unavailable')         and (states.light.guest_toilet_bulb_3_tuya.state != 'unavailable')}}"
          - "{{(states.light.living_room_landing_light_1_localtuya.state == 'unavailable') and (states.light.living_room_landing_light_1_tuya.state != 'unavailable')}}"
          - "{{(states.light.living_room_3_head_lamp_1_localtuya.state == 'unavailable')   and (states.light.living_room_3_head_lamp_1_tuya.state != 'unavailable')}}"
          - "{{(states.light.living_room_3_head_lamp_2_localtuya.state == 'unavailable')   and (states.light.living_room_3_head_lamp_2_tuya.state != 'unavailable')}}"
          - "{{(states.light.living_room_3_head_lamp_3_localtuya.state == 'unavailable')   and (states.light.living_room_3_head_lamp_3_tuya.state != 'unavailable')}}"
    action:
      # Wait for 1 min to confirm the the localtuya device is still offline
      - delay: "00:03:00"
      - condition: or
        conditions:
      - service: notify.mobile_app_tais_iphone_13_pro_max
        data:
          title: "Restarting HA in 1 Min"
          message: "A localtuya device is offline. Restarting HA to reload localtuya integration."
      # Do not run it too often
      - delay: "00:01:00"
      # Making HA restarts during this automation would likely make HA unable to capture the trace of this automation instance.
      - service: script.hassio_restart
发表于 2023-1-4 15:44:48 来自手机 | 显示全部楼层
自动化可以设置重载某个集成,就不用重启整个HA了
发表于 2023-1-4 15:33:25 | 显示全部楼层
治標不治本
发表于 2023-1-4 13:25:47 | 显示全部楼层
xiguaboy 发表于 2023-1-4 08:41
我觉得正确的思路应该是解决你的灯带的问题
同感,一但ha重启出问题,那影响的就不是一个灯带的事了。
发表于 2023-1-4 13:18:00 | 显示全部楼层
贰苍 发表于 2023-1-4 11:40
这是HA的自动化
谢谢!
发表于 2023-1-4 11:40:09 | 显示全部楼层
shayulei 发表于 2023-1-4 08:51
这是要写在config.yaml里吗?
这是HA的自动化
GMT+8, 2025-8-11 12:25 , Processed in 0.102121 second(s), 13 queries , MemCached On.
