查看: 13860|回复: 4
[求助] hassio中的moquitto配置问题
发表于 2020-6-18 16:14:48 | 显示全部楼层 |阅读模式
悬赏5金钱已解决
哪位大神可帮忙看一下
求教,我用的是N1中的Hassio安装mosquitto作为mqtt的服务器。
然后我的mqtt无法连接,日志报错内容如下:
Logger: homeassistant.components.mqtt
Source: components/mqtt/__init__.py:993
Integration: MQTT (documentation, issues)
First occurred: 下午3:35:59 (22 occurrences)
Last logged: 下午4:06:10
Disconnected from MQTT server (2)
然后我用的mosquitto addon的相关配置是:Supervisor/Mosquitto Broker/Configuration:
logins:
  - username: bmqtt
    password: bmqtt
anonymous: false
customize:
  active: false
  folder: mosquitto
certfile: aaa.pem
keyfile: aaa.key
require_certificate: false
然后我在HA的configuration.yaml中mqtt的部分如下:
mqtt:
  broker: 172.17.0.1 #备注,用的是docker中bridge网关的ip
  port: 1884
  username: bmqtt
  password: bmqtt
  discovery: true
万分感谢~
Black
最佳答案
查看完整内容
我的配置,不需要在configuration.yaml里配置,直接在mosquitto broker里配置 logins: - username: mqtt password: mqtt anonymous: false customize: active: false folder: mosquitto certfile: fullchain.pem keyfile: privkey.pem require_certificate: false 然后在集成里添加mqtt就可以了
发表于 2023-9-12 21:12:20 | 显示全部楼层
New connection from 172.30.32.1:47437 on port 1883.
2023-09-12 21:09:46: Client 4Yb**********e disconnected, not authorised.
大佬能帮忙解决一下吗。moquitto一直报错
 楼主| 发表于 2020-6-18 21:25:01 | 显示全部楼层
mabel198866 发表于 2020-6-18 17:47
不需要外网把anonymous: true,改成可以匿名登录试试
mqtt:
  broker: localhost #备注,用的是docker中bri ...
谢谢,我的用你的这个配置没跑通,用另外一个跑通了。但也很感谢你留言。
发表于 2020-6-18 17:47:55 | 显示全部楼层
mqtt:
  broker: localhost #备注,用的是docker中bridge网关的ip
  port: 1883
  username: bmqtt
  password: bmqtt
  discovery: true
发表于 2020-6-18 16:14:49 | 显示全部楼层
logins:
  - username: mqtt
    password: mqtt
anonymous: false
customize:
  active: false
  folder: mosquitto
然后在集成里添加mqtt就可以了
GMT+8, 2025-9-10 06:22 , Processed in 0.055234 second(s), 15 queries , MemCached On.
