斐讯Phicomm n1的冬瓜haos来了,虽然存在一定程度上的跳票,但是还是出来。
因为手边一直没有N1,本指着哪位寄一个给我调试一下,但又怕大家等得太急,于是入手闲鱼一台开工。
本是计划两天,结果遇到了N1的特殊性(刷砖的都知道),于是多花了1天多工时才搞完。,当然,其中驱动层调试的老大,身体抱恙不计算在内
哦,忘说了,其中出现了一台严重变砖(0x10103003)刷机错误,哪个会修的,可以私信我。
为了方便大家使用,特制作了新版的懒人包,请下载后直接解包后使用。
斐讯Phicomm n1 一台
U盘一个(usb2.0优先,建议不要少于16G)
windows电脑一台(本教程以windows教程为主,mac和linux的,请自行更改相应的软件)
键盘
1、下载烧录软件etcher
2、下载对应的冬瓜HAOS版本
下载链接:[冬瓜HAOS版本一体包(又叫懒人包)]
HAOS16.1
https://fw.wghaos.com/haos/phicomm-n1/Armbian_25.02.0_amlogic_phicomm-n1_jammy_5.15.165_haos_16.1.xz
HAOS16.0
https://fw.wghaos.com/haos/phicomm-n1/Armbian_25.02.0_amlogic_phicomm-n1_jammy_5.15.165_haos_16.0.xz
HAOS15.2
http://fw.wghaos.com/haos/phicomm-n1/Armbian_25.02.0_amlogic_phicomm-n1_jammy_5.15.165_haos_15.2.xz
HAOS15.1
http://fw.wghaos.com/haos/phicomm-n1/Armbian_25.02.0_amlogic_phicomm-n1_jammy_5.15.165_haos_15.1.xz
HAOS15.0
http://fw.wghaos.com/haos/phicomm-n1/Armbian_25.02.0_amlogic_phicomm-n1_jammy_5.15.165_haos_15.0.xz
HAOS14.2.1
http://fw.wghaos.com/haos/phicomm-n1/Armbian_25.02.0_amlogic_phicomm-n1_jammy_5.15.165_haos_14.2.1.xz
HAOS14.2
http://fw.wghaos.com/haos/phicomm-n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.165_haos_14.2.xz
HAOS14.1.1
http://fw.wghaos.com/haos/phicomm-n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.165_haos_14.1.1.xz
HAOS14.1
http://fw.wghaos.com/haos/phicomm-n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.165_haos_14.1.xz
HAOS14.0
http://fw.wghaos.com/haos/phicomm-n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.165_haos_14.0.xz
HAOS13.2.1
http://fw.wghaos.com/haos/phicomm_n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.165_haos_13.2.1.xz
HAOS13.2
http://fw.wghaos.com/haos/phicomm_n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.165_haos_13.2.xz
HAOS13.1.1
http://fw.wghaos.com/haos/phicomm_n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.165_haos_13.1.1.xz
HAOS13.1
http://fw.wghaos.com/haos/phicomm_n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.165_haos_13.1.xz
HAOS12.4.1
(http://fw.wghaos.com/haos/phicomm_n1/Armbian_24.5.0_amlogic_phicomm-n1_jammy_5.15.149_haos_12.4.1.xz)
HAOS12.4(http://fw.wghaos.com/haos/phicomm_n1/Armbian_24.5.0_phicomm_n1_jammy_5.15.149_haos_12.4.xz)
HAOS12.3.3
(http://fw.wghaos.com/haos/phicomm_n1/Armbian_phicomm-n1_haos12.3.3.rar)
HAOS12.3
(http://fw.wghaos.com/haos/phicomm_n1/Armbian_phicomm-n1_haos12.3.rar)
3、打开ethcher软件对U盘进行烧录
[attach]57079[/attach]
[attach]57080[/attach]
[attach]57081[/attach]
[attach]57082[/attach]
1、开启N1进入设置界面,查看网络IP信息,如果IP地址显示是IPv6的话就拔插一下网线即可。
[attach]57087[/attach]
2、将烧录好冬瓜HAOS的U盘插到N1上(靠近HDMI侧)。下载冬瓜adbcmd运行“双击改U盘启动.bat”批处理文件。输入盒子的IP地址,系统将会重启进入到ARMbian。
[attach]57088[/attach]
1、这次我们贴心的把设置账号、密码等环节都设置好了,直接就能进入系统,主打就是省事!
2、插入键盘运行脚本,按照提示输入序号即可。
./zwgusb2haos_phicomm-n1 # 运行烧录脚本
[attach]63182[/attach]
3、(不是必须操作步骤)使用SSH连接可以通过-C查看中文的安装进度。
username:root
password:1234
[attach]57089[/attach]
4、烧录完成后断电拔除U盘,再插上网线上电进入HomeAssistant。
5、进入到HomeAssistant主界面后输入命令。
login # 登录系统
ha-install -t # 查看初始化进度
[attach]57084[/attach]
注:如果安装卡在install waxgourd addons repositories.
重启系统便可,这是南京大学镜像站有时不太稳定导致。
6、安装完成后按ctrl + c 退出查看,输入命令重启HomeAssistant。
ha host reboot # 重启HomeAssistant
[attach]57085[/attach]
7、通过http://<IP>:8123
访问HomeAssistan。
[attach]57086[/attach]
wangmucha 发表于 2024-3-13 02:50
请问斐讯T1盒子能刷吗?跟n1很相似
ghostist 发表于 2024-3-13 08:46
下一步可以安排玩客云了 好像也是8G?
冬瓜HA 发表于 2024-3-13 08:39
T1和N1不一样,我过几天出T1的
花落花空 发表于 2024-3-13 08:55
玩客云太拉了吧。。。重点是只有1g运存、。。。
ghostist 发表于 2024-3-13 09:08
我到现在也不觉得运行HA需要什么强的硬件
不跑视频处理相关的东西,其他不就是协议转换嘛
ARM的盒子、X86 ...
空白 发表于 2024-3-13 19:49
emmc容量不够,大佬可以刷u盘吗
冬瓜HA 发表于 2024-3-14 10:46
不过你要从懒人包中,把里面的xz复制出来,然后解压,得到一个IMG,来制作U盘 ...
上帝在堕落 发表于 2024-3-14 21:53
借个楼,大佬panther-x2的HAOS中的南大的源404了,麻烦更新一下,谢谢.
冬瓜HA 发表于 2024-3-14 22:24
南大源,晚上堵车,白天用超好用
哈哈,反正我都快乱套了,见问就回复。都不管出处了。 ...
bhc1365 发表于 2024-3-15 19:37
是可以直接在U盘里运行haos吗?
冬瓜HA 发表于 2024-3-15 19:43
原则上可以
AnyLine 发表于 2024-3-15 10:16
写入EMMC第一步也是这吧,需要先在U盘里运行起来。
不写入EMMC就插U盘跑;写入EMMC就执行写入命令后,重启 ...
bhc1365 发表于 2024-3-16 09:32
怎样才能在U盘里运行呢?
冬瓜HA 发表于 2024-3-16 10:07
放在1楼贴的最后面了
bhc1365 发表于 2024-3-16 13:29
是用解压出来的img替换原来的zx吗?具体怎样操作请指教。谢谢
zyling 发表于 2024-3-16 12:28
对了,HASSIO上生成的备份文件,可以恢复到楼主冬瓜版HAOS上使用吗?
冬瓜HA 发表于 2024-3-16 15:45
解压出来的img直接刷U盘
zyling 发表于 2024-3-16 20:33
作好U盘引导了,也查到了N1获取的IP,但SSH连接进去,root的密码是什么呢?
zyling 发表于 2024-3-16 21:02
ha > login
root@homeassistant:/ # ha-install -t
patch end.
ha > login
patch end.
zyling 发表于 2024-3-16 22:46
太棒了,把备份恢复就完美运行起来了。
马上提示有12.1版。先不更新了。
冬瓜HA 发表于 2024-3-17 00:05
haos的ssh是用证书的
https://developers.home-assistant.io/docs/operating-system/debugging/
不会再问 ...
zyling 发表于 2024-3-17 13:14
谢谢您!
当冬瓜HAOS提示更新时,是否可以跟随官方固件正常升级呢?
bhc1365 发表于 2024-3-17 12:08
有没有人不写入emmc,在U盘里直接运行的?
下一步可以安排玩客云了 好像也是8G?
rmyyzf 发表于 2024-3-20 16:25
写入HAOS后怎么来再配置 IP地址???(是因为我N1已经安装了armbian系统安装HAssio的,在用群主的img写的 ...
冬瓜HA 发表于 2024-3-20 17:11
,我的img的U盘启动太快,所以IP地址显示不出来,你要再查,ip r s能看到。
HAOS配置IP?除非你没接 ...
anbeen 发表于 2024-3-20 21:41
用 etcher把img 文件刷入 u 盘,不能启动。我刷的 armbian 是能用 u 盘直接启动的。请问是怎么回事呢?
冬瓜HA 发表于 2024-3-20 22:05
我没具体试,明天我试一下。
rmyyzf 发表于 2024-3-20 22:22
我是正常写入U盘后启动的
空白 发表于 2024-3-20 23:58
大佬,启动不了是不是因为u-boot-2015-phicomm-n1.bin这个没写入啊,我看你给的截图一共做了两件事,一个是 ...
我是正常写入U盘后启动的
zyling 发表于 2024-3-21 10:54
稳定运行了好几天了,真不错。
但是,系统日志里总有一大堆红色的错误,这样不影响吧? ...
anbeen 发表于 2024-3-21 09:06
img 文件刷到 u 盘?直接在 u 盘上运行 ?我怎么就启动不了呢
冬瓜HA 发表于 2024-3-21 12:01
你这个错误是应该是装了老版本之类的addons出错了导致的。没有问题的,supervisor有很好的自修复功能,如 ...
我没具体试,明天我试一下。
anbeen 发表于 2024-3-21 17:23
能刷到 u 盘上运行吗?
冬瓜HA 发表于 2024-3-21 17:25
还没试完,正在测
sxjhxu 发表于 2024-3-22 21:18
大佬 8g的备份提示剩余空间0.6g,不能备份 有办法解决吗
cooliscool 发表于 2024-3-25 16:43
前面都ok,最后登录出问题。
还没试完,正在测
anbeen 发表于 2024-3-25 17:52
能在 u 盘上运行了吗?
冬瓜HA 发表于 2024-3-25 18:43
内部讨论了一下,不考虑了
cooliscool 发表于 2024-3-26 09:35
刷完进去后,没找到hacs喔,过程中看到是有安装的。
ha折腾无极限 发表于 2024-3-26 13:15
感谢冬瓜大佬(喊 1000 遍牛逼!!),已顺利将 N1 刷上冬瓜 HAOS 12.0。
刚刷好就收到系统升级提示:OS ...
冬瓜HA 发表于 2024-3-26 11:18
配置--设备与服务--添加集成(右下角)--搜索hacs,然后进行激活
cooliscool 发表于 2024-3-27 09:36
已经集成加进去,但是Node和Terminal 都没法应用
一直这样循环中
stefand 发表于 2024-3-27 17:57
第一步烧录镜像就一直出错,不知道哪里出了问题
stefand 发表于 2024-3-27 18:01
好像是u盘问题,弹出重插解决了
stefand 发表于 2024-3-27 18:22
利用adb进入U盘启动模式
闻彬 发表于 2024-3-27 21:16
请问大佬,N1的wifi能用吗?
shhleo 发表于 2024-3-30 10:46
第一步烧录成功后(烧录过程屏幕一直显示正常),拔掉u盘插网线重启,怎么显示花屏,屏幕能看到文字在跳动 ...
