标题: 新人求助!启动HA报错,停滞了几个月了。。。。 [打印本页]
作者: chenzz1228    时间: 2023-10-18 20:43
日志信息如下,windows11VM虚拟机
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[12:38:52] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[12:38:52] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
23-10-18 12:38:54 INFO (MainThread) [__main__] Initializing Supervisor setup
23-10-18 12:38:54 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-10-18 12:38:54 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
23-10-18 12:38:54 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.10.0
23-10-18 12:38:54 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-10-18 12:38:54 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
23-10-18 12:38:54 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-10-18 12:38:54 INFO (MainThread) [__main__] Setting up Supervisor
23-10-18 12:38:55 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-10-18 12:38:55 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-10-18 12:38:55 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-10-18 12:38:55 INFO (MainThread) [supervisor.host.services] Updating service information
23-10-18 12:38:55 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-10-18 12:38:55 INFO (MainThread) [supervisor.host.network] Updating local network information
23-10-18 12:38:55 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-10-18 20:38:58 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-10-18 20:38:58 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-10-18 20:39:00 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-10-18 20:39:00 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0
23-10-18 20:39:00 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-10-18 20:39:00 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.06.0 - 172.30.32.5
23-10-18 20:39:00 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-10-18 20:39:00 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2
23-10-18 20:39:00 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-10-18 20:39:01 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3
23-10-18 20:39:01 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-10-18 20:39:01 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-10-18 20:39:01 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0
23-10-18 20:39:01 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-10-18 20:39:01 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.06.0 - 172.30.32.4
23-10-18 20:39:01 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2023.06.0'>]
23-10-18 20:39:01 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
23-10-18 20:39:01 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-10-18 20:39:02 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
23-10-18 20:39:02 INFO (MainThread) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2023.06.2'>]
23-10-18 20:39:02 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2
23-10-18 20:39:02 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-10-18 20:39:02 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host
23-10-18 20:39:02 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-10-18 20:39:02 INFO (MainThread) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
23-10-18 20:39:02 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
23-10-18 20:39:02 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-10-18 20:39:02 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-10-18 20:39:02 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-10-18 20:39:02 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-10-18 20:39:02 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
23-10-18 20:39:02 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 11.0 / BootSlot A
23-10-18 20:39:02 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-10-18 20:39:02 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-10-18 20:39:02 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-10-18 20:39:24 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/home-assistant/addons /data/addons/core
  stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': Recv failure: Connection reset by peer
23-10-18 20:39:24 ERROR (MainThread) [supervisor.store] Can't retrieve data from core due to
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / core
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / core
23-10-18 20:39:24 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
  stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Recv failure: Connection reset by peer
23-10-18 20:39:24 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.module] Create new suggestion execute_remove - store / a0d7b954
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
23-10-18 20:39:24 INFO (MainThread) [supervisor.store] Loading add-ons from store: 3 all - 3 new - 0 remove
23-10-18 20:39:24 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-10-18 20:39:24 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-10-18 20:39:24 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-10-18 20:39:24 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-10-18 20:39:24 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
23-10-18 20:39:24 INFO (MainThread) [__main__] Running Supervisor
23-10-18 20:39:24 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-10-18 20:39:24 INFO (MainThread) [supervisor.addons] Phase 'initialize' starting 0 add-ons
23-10-18 20:39:24 INFO (MainThread) [supervisor.addons] Phase 'system' starting 0 add-ons
23-10-18 20:39:24 INFO (MainThread) [supervisor.addons] Phase 'services' starting 0 add-ons
23-10-18 20:39:24 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-10-18 20:39:24 INFO (MainThread) [supervisor.addons] Phase 'application' starting 0 add-ons
23-10-18 20:39:24 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-10-18 20:39:24 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-10-18 20:39:24 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-10-18 20:39:24 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2023.10.3
23-10-18 20:39:24 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2023.10.3.
23-10-18 20:39:24 INFO (MainThread) [supervisor.host.info] Updating local host information
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-10-18 20:39:24 INFO (MainThread) [supervisor.host.services] Updating service information
23-10-18 20:39:24 INFO (MainThread) [supervisor.host.network] Updating local network information
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-10-18 20:39:24 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-10-18 20:39:24 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-10-18 20:39:24 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-10-18 20:39:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-10-18 20:39:25 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-10-18 20:39:25 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
作者: zhengxinfjpt    时间: 2023-10-18 20:56
正常启动。上梯子就好了。
作者: chenzz1228    时间: 2023-10-18 22:02
zhengxinfjpt 发表于 2023-10-18 20:56
正常启动。上梯子就好了。
准备界面提示报错了,而且上了梯子十几个小时都没用
作者: sasukebinbin    时间: 2023-10-19 01:11
从日志上看的确是网络的问题. 梯子的问题?
作者: chenzz1228    时间: 2023-10-19 07:14
sasukebinbin 发表于 2023-10-19 01:11
fatal: unable to access 'https://github.com/home-assistant/addons/': Recv failure: Connection reset  ...
换了两三个梯子啦,但是梯子都能打开谷歌和github,很无奈
作者: sasukebinbin    时间: 2023-10-19 15:36
会不会是虚拟机没有上到梯子
作者: chenzz1228    时间: 2023-10-19 15:50
sasukebinbin 发表于 2023-10-19 15:36
会不会是虚拟机没有上到梯子
感觉是我的网络问题但是找不到具体原因,之前在学校用宿舍的网正常,自从回家以后就一直这样了,同一台电脑
作者: shayulei    时间: 2023-10-24 16:05
现在网络环境是差的,我的HA已经好久没有升级成功了!
