标题: (已解决)Docker版HA Supervisor官方已放弃?不再更新? [打印本页]
作者: 623305170    时间: 2023-8-25 22:36
我用的主机是N1,使用docker的方式安装的HA supervisor,现在HA官方已经把HAOS和supervisor更新到2023.08.1了,但是docker版一直未更新,supervisor最新版依然是老版本2023.06,官方2个多月未更新docker版supervisor了
作者: wbdownn    时间: 2023-8-25 22:44
还想着转成docker的
作者: 623305170    时间: 2023-8-25 22:53
我在github上转了一圈,发现同样有人发现这个问题了,但作者并未明确答复,只说了参阅2023.7的发行说明,我跟提问者一样一头雾水,发行说明中并未提及为什么不更新docker镜像的原因
作者: leonarddo    时间: 2023-8-26 06:02
现在更新在ghcr.io上,不在hub.docker上
作者: leonarddo    时间: 2023-8-26 06:09
https://www.home-assistant.io/bl ... 7/#breaking-changes
Home Assistant Container (Docker)
If you use the Home Assistant Container installation method, for example, using Docker, please make sure you are using our official (multi-platform) images.
The correct and preferred image to use for our stable releases is:
ghcr.io/home-assistant/home-assistant:stable
Although not the preferred location by the Home Assistant project, the image is also available on DockerHub:
homeassistant/home-assistant:stable
The reason for mentioning this in this breaking change section is that we have seen usage of our internal, intermediate, platform build images. These images are not meant for use directly, and using the above listed images is strongly recommended.
As of this release, we no longer publish our intermediate platform images to DockerHub. This means that if you are using these images, you will no longer receive updates. Please use the above-listed images instead.
作者: 623305170    时间: 2023-8-26 17:27
感谢,已成功更新
作者: rudaa    时间: 2023-9-8 22:23
你好,楼主,我也是N1,能分享一下拉取代码吗?
作者: zwkilo    时间: 2023-9-10 20:53
对的 ,但是ghcr.io 的拉取速度真的一言难尽
作者: zwkilo    时间: 2023-9-10 20:56
docker pull ghcr.io/home-assistant/qemux86-64-homeassistant:2023.9.0
docker pull ghcr.io/home-assistant/amd64-hassio-supervisor:2023.08.3
我这是x86 的 你自己改一下
作者: rudaa    时间: 2023-9-10 22:48
docker pull ghcr.io/home-assi ...
好的,非常感谢!!
