2023-08-11T10:53:15.707Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict [email protected]
2023-08-11T10:53:16.039Z [err] npm WARN config production Use `--omit=dev` instead.
2023-08-11T11:00:53.872Z [err] npm ERR! code
2023-08-11T11:00:53.872Z [err] ETIMEDOUT
2023-08-11T11:00:53.872Z [err] npm ERR! syscall connect
2023-08-11T11:00:53.872Z [err] npm ERR! errno ETIMEDOUT
2023-08-11T11:00:53.875Z [err] npm ERR! network request to https://registry.npmjs.org/node-red-contrib-bizwechat-apiproxy failed, reason: connect ETIMEDOUT 2606:4700::6810:23:443
2023-08-11T11:00:53.875Z [err] npm ERR! network This is a problem related to network connectivity.
2023-08-11T11:00:53.875Z [err] npm ERR! network In most cases you are behind a proxy or have bad network settings.
2023-08-11T11:00:53.875Z [err] npm ERR! network If you are behind a proxy, please make sure that the
2023-08-11T11:00:53.875Z [err] ERR! network
2023-08-11T11:00:53.875Z [err] 'proxy' config is set properly. See: 'npm help config'
2023-08-11T11:00:53.877Z [err]
2023-08-11T11:00:53.877Z [err] npm ERR! A complete log of this run can be found in: /root/.npm/_logs/2023-08-11T10_53_16_009Z-debug-0.log
2023-08-11T11:00:53.885Z rc=1作者: fjcy233 时间: 2023-10-21 21:01
楼主解决了吗,我也一样问题作者: Dlian 时间: 2023-10-24 12:19
